You've made sure the file is saved as a .xml not as a .txt?
What is the exact syntax you used in the file?
<cc_config>
<log_flags>
</log_flags>
<options>
<exclusive_app>SC2Game.exe</exclusive_app>
<report_results_immediately>1</report_results_immediately>
<client_version_check_url>http://www.worldcommunitygrid.org/download.php?xml=1</client_version_check_url>
<client_download_url>http://www.worldcommunitygrid.org/download.php</client_download_url>
<network_test_url>http://www.ibm.com/</network_test_url>
<start_delay>120</start_delay>
</options>
</cc_config>
Hmmm ... I copied what you posted and told it to read the local config file and got:
edit: I'm using 6.10.36 (64bit if it matters)Quote:
Mon 22 Mar 2010 17:53:43 EST Re-reading cc_config.xml
Mon 22 Mar 2010 17:53:43 EST Re-read config file
Mon 22 Mar 2010 17:53:43 EST Config: report completed tasks immediately
Mon 22 Mar 2010 17:53:43 EST Config: don't compute while SC2Game.exe is running
Mon 22 Mar 2010 17:53:43 EST log flags: file_xfer, sched_ops, task
Mon 22 Mar 2010 17:53:48 EST World Community Grid Sending scheduler request: To report completed tasks.
Mon 22 Mar 2010 17:53:48 EST World Community Grid Reporting 1 completed tasks, not requesting new tasks
using 6.2.28 version
I guess the new version breaks it?
6.10 is substantially newer than 6.2, you should probably upgrade.
https://secure.worldcommunitygrid.or...wnloadAgain.do
Ummm you sure?
Since its the latest client available to download.
Or does WCG not keeping up with the times?
You have the same problem I did. The suspend stuff only works with 6.4 and later.
Consolidated starter list for those wanting to not crunch while gaming:
This includes the games contributed by everyone in this thread as well as my own, sorted alphabetically, and without duplicates. I actually made an app just for this, so we can consolidate lists quite easily. Please PM me your cc_config lists! :D
Code:<cc_config>
<options>
<exclusive_app>age2_x1.exe</exclusive_app>
<exclusive_app>alice.exe</exclusive_app>
<exclusive_app>arma2.exe</exclusive_app>
<exclusive_app>Audiosurf.exe</exclusive_app>
<exclusive_app>BFBC2Game.exe</exclusive_app>
<exclusive_app>BGMain.exe</exclusive_app>
<exclusive_app>Bioshock.exe</exclusive_app>
<exclusive_app>Bioshock2.exe</exclusive_app>
<exclusive_app>Civ4BeyondSword.exe</exclusive_app>
<exclusive_app>CoCMainWin32.exe</exclusive_app>
<exclusive_app>CoD2SP_s.exe</exclusive_app>
<exclusive_app>Crysis.exe</exclusive_app>
<exclusive_app>d1x-rebirth-gl.exe</exclusive_app>
<exclusive_app>DeusEx.exe</exclusive_app>
<exclusive_app>Diablo II.exe</exclusive_app>
<exclusive_app>Dirms.exe</exclusive_app>
<exclusive_app>DungeonSiege2.exe</exclusive_app>
<exclusive_app>ePSXe.exe</exclusive_app>
<exclusive_app>ET.exe</exclusive_app>
<exclusive_app>FarCry.exe</exclusive_app>
<exclusive_app>FarCry2.exe</exclusive_app>
<exclusive_app>ForgedAlliance.exe</exclusive_app>
<exclusive_app>Frozen Throne.exe</exclusive_app>
<exclusive_app>fuhquake.exe</exclusive_app>
<exclusive_app>glquake.exe</exclusive_app>
<exclusive_app>glqwclient.exe</exclusive_app>
<exclusive_app>H5_Game</exclusive_app>
<exclusive_app>hl -console.exe</exclusive_app>
<exclusive_app>hl.exe</exclusive_app>
<exclusive_app>hl2.exe</exclusive_app>
<exclusive_app>Homeworld2.exe</exclusive_app>
<exclusive_app>iw3mp.exe</exclusive_app>
<exclusive_app>iw3sp.exe</exclusive_app>
<exclusive_app>iw4mp.exe</exclusive_app>
<exclusive_app>iw4sp.exe</exclusive_app>
<exclusive_app>IWD2.exe</exclusive_app>
<exclusive_app>Jazz2.exe</exclusive_app>
<exclusive_app>JediAcademy.exe</exclusive_app>
<exclusive_app>left4dead.exe</exclusive_app>
<exclusive_app>left4dead2.exe</exclusive_app>
<exclusive_app>masseffect.exe</exclusive_app>
<exclusive_app>MirrorsEdge.exe</exclusive_app>
<exclusive_app>MOHA.exe</exclusive_app>
<exclusive_app>nations.exe</exclusive_app>
<exclusive_app>NFSHP2.exe</exclusive_app>
<exclusive_app>nwn2main.exe</exclusive_app>
<exclusive_app>patriots.exe</exclusive_app>
<exclusive_app>Penumbra.exe</exclusive_app>
<exclusive_app>quake.exe</exclusive_app>
<exclusive_app>RedOrchestra.exe</exclusive_app>
<exclusive_app>RelicCOH.exe</exclusive_app>
<exclusive_app>Requiem.exe</exclusive_app>
<exclusive_app>rfg.exe</exclusive_app>
<exclusive_app>rise.exe</exclusive_app>
<exclusive_app>shattered_horizon.exe</exclusive_app>
<exclusive_app>shock2.exe</exclusive_app>
<exclusive_app>Soulstorm.exe</exclusive_app>
<exclusive_app>Speed.exe</exclusive_app>
<exclusive_app>Spybot.exe</exclusive_app>
<exclusive_app>SR2_pc.exe</exclusive_app>
<exclusive_app>starcraft.exe</exclusive_app>
<exclusive_app>SupremeCommander2.exe</exclusive_app>
<exclusive_app>thrones.exe</exclusive_app>
<exclusive_app>Titan Quest.exe</exclusive_app>
<exclusive_app>torment.exe</exclusive_app>
<exclusive_app>UT3.exe</exclusive_app>
<exclusive_app>witcher.exe</exclusive_app>
<exclusive_app>xrEngine.exe</exclusive_app>
</options>
</cc_config>
Thanks particle:up: very nice
i personally don't play any games, but you can add starcaft 2 to the list. it's not too CPU demanding, but it might help.
Got it work >.>
WCG should update that client.
They SHOULD do a few things, but the wheels at IBM turn slowly. ;)
From the context, my guess would be he downloaded a client dated later than the officially listed build on their website. Such an action is required to get it to work.
Code:<cc_config>
<options>
<exclusive_app>Borderlands.exe</exclusive_app>
<exclusive_app>DAOrigins.exe</exclusive_app>
<exclusive_app>Doom3.exe</exclusive_app>
<exclusive_app>Glquake.exe</exclusive_app>
<exclusive_app>jk2sp.exe</exclusive_app>
<exclusive_app>jk2mp.exe</exclusive_app>
<exclusive_app>JK.exe</exclusive_app>
<exclusive_app>JKM.exe</exclusive_app>
<exclusive_app>MassEffect2.exe</exclusive_app>
<exclusive_app>Majesty2.exe</exclusive_app>
<exclusive_app>metro2033.exe</exclusive_app>
<exclusive_app>MonkeyIsland101.exe</exclusive_app>
<exclusive_app>MonkeyIsland102.exe</exclusive_app>
<exclusive_app>MonkeyIsland103.exe</exclusive_app>
<exclusive_app>MonkeyIsland104.exe</exclusive_app>
<exclusive_app>MonkeyIsland105.exe</exclusive_app>
<exclusive_app>quake2.exe</exclusive_app>
<exclusive_app>quake3.exe</exclusive_app>
<exclusive_app>SamHD.exe</exclusive_app>
<exclusive_app>Shadowgrounds.exe</exclusive_app>
<exclusive_app>survivor.exe</exclusive_app>
<exclusive_app>winquake.exe</exclusive_app>
</options>
</cc_config>
:p:
I find the new "suspend if CPU load exceeds XX %" option that BOINC manager now has to VERY useful on my mainrig.
While gaming with BOINC running in the background, I always had the issue of increased loading times (by a factor of 2 or 3 - whyever that is) but almost never any lags that actually occured in-game.
So now, when a game is loading, it draws a little CPU (I think I set 15% because 25% just isn't ever reached on a hexacore :ROTF: ), BOINC shuts off for a few seconds, game loads quickly, BOINC auto-reenables, bingo :)
Just very few games where BOINC really needs to be shut off to play. NFS series is a good example, and some shooters. RTS are all fine, for example - currently playing the new C&C 4.
@SoulsCollective:
Pfff, most of these games show no difference at all with BOINC running - SupremeCommander 2 for example :p:
No wonder your output is so low, with THAT ccconfig file :sofa: :p:
Interesting, I find RTS titles to be the most CPU-intensive.
More than a few of the titles are not my additions - I've simply added to the larger list Particle posted above (which is itself based in part on my older listed posted previously).Quote:
@SoulsCollective:
Heh, nope, that would be due to not returning any results for the past five months due to rising summer temps (and therefore air-con and therefore electricity costs) down here.Quote:
Ok, found one RTS that doesn't run smoothly with WCG running.. World in Conflict :shakes:
So I had to exit BOINC and forgot to re-enable.. there went my Blueberry Pie yesterday :rolleyes:
So to make sure that doesn't happen again, I put it in exclusive apps along with NFS and a few others I know don't run with BOINC. Just tried starting it up, and it works :)
