That's correct. The only thing i couldn't quite understand was the author's i7-965 comment under the chart with power consumption numbers. Both CPUs tested should be 2.4Ghz models.
If BD is not 2011 thing anymore(as you say),when is it supposed to launch then?!
BD cores are now already in 2nd major revision,first being "canceled" back in the 2007.Since then,it "gained" 256bit AVX support and SSE5 on top of that(XOP etc. in new renamed nomenclature).
So Chad is right,BD is in best case scenario late 2010,or in worst case Q2 2011.
