Is there a way to hook up the Aquaero so it is always on and can power & control whatever connected to it when your computer is off? Are we talking about some kind of AC/DC power converter or relay switch? I bet there's something outside computer electronics in general power management electronics that can provide whatever the controller needs, but it would be nice for it to be able to be set dependent to computer power or manually on/off like the relay below.
What about this Sunbeam 110V/220V AC Pump Relay Switch @ PPCs? Can it fully power an Aquaero with Powerboost and/or a Poweradjust? Product specs, according to PPPCs:
The Sunbeam Pump Relay Kit can be applied in a water cooling system that uses AC water pump or other devices using external AC power that require to be turned on/off at the same time with the PC. Connect AC source, DC source and water pump to the relay board. If the system is setup correctly, the water pump would be turned on when the PC is turned on. When the PC is shutdown, the Sunbeam Pump Relay Kit would detect that 12V DC power from PC power supply is cut off, and, thus, turn off the AC pump.
FEATURES:
* Can be used in any country.
* Toggle switch - bleed your system with the computer off
* On board relay controlled by PCI Bus
* External Molex 12VDC connection for external fan power
* Inline fuse for overload protection
* No case modifications for installation
* Compact design
* Easy operation, plug it in your PCI slot, plug in the AC cord through the power inlet on the PCI flange, and then hook up your pump wires to the pump terminal.
SPECIFICATIONS:
* 12VDC external power (5 watts max)
* 2 amp fuse (200 watts maximum draw)
* 110VAC / 220VAC design for worldwide power compatibility
* CE compliant, UL listed components and designed.
