T.Rex, real Vgpu max with soft is ~1,49V (due to the IC). You can move the slider forward, but Vgpu doesn't rise ;)
your canyon looks weak
but i dont know AMD CPUs very well
it would be nice if you had Intel tests as well
1.4v is the limit actually not 1.49v
rivatuner report ? of 1325MHZ
why (ur/watch) stop all performance,at (MAX MHZ SET) in bios,(ur/watch)/gpu has a limit.
i can clock high to,but gives no more in 3d,but more voltset help
within the max limit of (ur/watch).
next time you hit 1325MHZ ,get a rivatuner report to:up:
you ned a (ur/watch)which goes up to 1400/1500 MHz to the gpu max set, so I will show you a boost you get in performance;)
so max must be in 1100 with this (ur/watch) here, http://forums.techpowerup.com/attach...8&d=1245187251
had the same problem with the 3870x2 and (ur/watch) http://www.hwbot.org/result.do?resultId=805978 oc proceeded to watch the service was to fall, even with more volts .
using XP 32BIT GPUTOOL ver:0.0.0 to a MSI 4890 OC
dinos22, I just rechecked Vgpu on my Sapphire and it reads ~1,488V under load. I use GPUTool to change Vgpu...
ok T.REX
you can get tlf:nr on octeamdenmark/msn ;)
And you would be 100% correct except for voltage ;) under normal circumstances.
Phase ( mach1 ) 720 BE card on air AC cooled room.
http://chew.ln2cooling.com/qdig-file...rg_biosmod.JPG
What SF3D has is the missing piece to my puzzle and bios mod that I have been working on and saying for a while and getting told NO NO NO.......software works fine.
Glad this is coming from him and macci.
ATI cards can be funny when pushed too hard or at the wrong clocks
but he very well may have a card that is capable of benching with stable 3D numbers past 1250 who knows heh
to be honest 1.4v was something i was told recently. i benched 4890s and have returned them since without checking with DMM but if it says 1.488v that should be pretty good for high LN2 clocks
Petri and me tested the bios thursday-night, but it's not all positive news. I'm not sure if I can talk about this ... so you'll have to wait for SF3D to update.
Yah no problems with this bios toasting anything not that that bios your on did at least I hope it didn't.
I to have tested on a stack of cards.....other than the weird screen over 1065 core....no issues. Of course I have not played cold on them but I doubt it will make a diff.....I know there is a bug just haven't found it yet. The screen issue is funky to.....03 gives gray/darker gray lines......vantage is hilarious a colorful reddish/orange/pink screen with an AMD logo.
Software clock the cards easily higher.......however according to results well USE whats fast......not what you think is fast. Canyon points to the fact that software is not working.
Vantage screen stutters like crazy when loading using software.....scores lower......
This bios was done solely by me no outside help, It also only works on ref cards...
These secret BIOS' hardly matter considering how much power there is in 4x HD4890 at 1GHz, let alone stock. This is like HD4870x2 CFX, you are already CPU bottlenecked at 850/950 and see scaling in only 03. Plus chew*, you need LHe to be competitive on AMD :D
What we need is another Vantage to even things out, Vantage sort of keeps scaling, especially High/Extreme, so where is 3DMark2010?
ehh scaling dies at 6.2 with 2 cards...till you increase clocks over 1000/1150....then they scale again.
As for Lhe...eh 6390 3d stable on ln2 nothing to cry about.....see If i can push the bar higher in the future.....
