Thanks guys. I tried with and without SLI. Same results are far as time goes. Also the gpu utilization was exactly the same both ways.
And when I did Gpugrid I had SLI disabled most of the time and still got errors.
I might try freeing up a core to see if it helps.
Edit: Free'd up a core. Didn't help.
Disabled SLI and did 2 WU per gpu and it wasnt laggy but it wasnt using more gpu% (except maybe a little on gpu0). Figured it might be a cpu bottleneck but I paused WCG and nothing changed still.
About time to send this card out of the window! :D
@Snow Crash
No, not jet;) I´m crunching for my own team for 6 years now. My e@h nick is hotze33.
Ever since that last post I've been running 2 WU per gpu (SLI off) and I gave it a little time to settle in.
Looking at the estimated times in BOINC and the actual run time on the e@h website results page it seems that they're just taking twice as long to finish.
Leading me to believe that maybe they aren't getting enough data from the cpu... but I've been keeping an eye on the cpu usage and it's no where close to using much. Also, even stopping WCG doesn't effect it.
Renaming my app_info to disable it. Not worth the extra hassle if it doesn't do extra work. :D
I reached my goal for top 10 on the team. I'll be moving on now. Not sure what next though. :)
So long E@H. :D
