could i get a measurement between the top of the motherboard and the top of the case? there seem to be a few different answers here...
here is mine, with brand new cm megaflow on side panel:)
http://img269.imageshack.us/img269/7...2009108.th.jpg http://img198.imageshack.us/img198/3...2009107.th.jpg http://img10.imageshack.us/img10/678...0091599.th.jpg http://img5.imageshack.us/img5/9628/290720091598.th.jpg
cool as ice
Here is an update of my system
http://img94.imageshack.us/img94/6321/dsc01605.jpg
http://img26.imageshack.us/img26/7388/dsc01610qf.jpg
http://img88.imageshack.us/img88/8453/dsc01602.jpg
http://img94.imageshack.us/img94/6161/dsc01609.jpg
http://img129.imageshack.us/img129/9718/004xa.jpg
http://img27.imageshack.us/img27/7193/dsc01622eq.jpg
Here are some pics with the CM Sniper/HAF922 side window panel on it. Not bad for $10.....
http://img197.imageshack.us/img197/5365/dsc01649v.jpg
http://img197.imageshack.us/img197/2420/011od.jpg
http://img34.imageshack.us/img34/695/012qb.jpg
Nice build! +5 :)
Is that sidepanel the Cm sniper window panel?
And what 360mm rad you are using there?
Thanks in advance :)
Heres mine on its 2nd day up and running after leak testing
http://i213.photobucket.com/albums/c...1/IMG_0024.jpg
http://i213.photobucket.com/albums/c...1/IMG_0019.jpg
http://i213.photobucket.com/albums/c...1/IMG_0018.jpg
Most ppl usually cut out only the mesh area for a window. But I thought that was a little small. So I cut mine a little wider and just bent the acrylic window a little to match the panel.
Nice set up. Great job on the window as well.
Lol, 10$??
Here in europe it's 30 euro,thats about 45$...
I believe this is a Europe site here.
that side panel fit ok no problems?
they sell it on the coolermaster website for i think $10
Very nice build Aviduser!
just bought mine today along with the 200x200x30mm megaflow fan for the side panel...
so the sniper clear side panel will fit the 922 with no problems? any mods needing made for it?
Hi Andrea deluxe, tell me, this vented pci slot are Nexus pci-300? Thanks a lot.
ok got mine painted and back together now here is some preREinstall of all my stuff.
http://i72.photobucket.com/albums/i1...DSC_0464-1.jpg
http://i72.photobucket.com/albums/i1...DSC_0467-1.jpg
http://i72.photobucket.com/albums/i1...t/DSC_0468.jpg
that was before i started to put anything back in it.
finished product. minus some wire cleaning up.
http://i72.photobucket.com/albums/i1...t/DSC_0483.jpg
http://i72.photobucket.com/albums/i1...t/DSC_0484.jpg
http://i72.photobucket.com/albums/i1...t/DSC_0486.jpg
http://i72.photobucket.com/albums/i1...t/DSC_0488.jpg
http://i72.photobucket.com/albums/i1...t/DSC_0489.jpg
Congratulations triggs75,this haf 922 is the most beautiful I've ever seen in my life.
This is my next case for sure.
hi
Is possible to add the wheels to this case?
Regards
Ugo merlini
Hi
some was able to install the Xigmatek XLF-2006 Blueline LED 200mm fan in front?
exist a way adapt a led light to the two pin on / off button?
Regards
Ugo
