Thank you!
How high is the BCLK and are QPI, IOH and ICH Voltages? My BCLK is 215.
Thank you!
20 years of building PCs and you are trying to say you lost 3k points on Vantage because you used a PCI soundcard on slot 3?
I'll be the one to decide which board is up my alley and please don't talk to me in this condescending manner. I just asked you some simple questions which you apparently can't answer so just leave it at that. I'll just wait and hope some of the other people here who have the board can actually post something valuable about the board rather than just show off that they own it.
I wish you guys would hurry up and decide whether or not this board is the stuff or not for overclocking compared to the Classified because my 760 is here and I haven't opened it yet thinking I may get a different board lol. I'm considering picking up the Asus R2E instead of using this Classified but I don't know if I will. I've kind of gotten a sour taste in my money for eVGA after all these RMA issues I've seen people having lately.
Yeah i read about the guy with the melted socket on evga forums lol.
RIIE is a good board , a little toasty but good.
Classified from what i hear clocks good , but very toasty.
P6t7 is a new board, so not proven yet,needs bios update ,but not as toasty
as the other two.
I think theres a you tube video on the p6t7 with it clocked to 4.5 with 3-way sli + physx.
If you don't plan on using multiple cards , then id get the RIIE.
any cold boot issues with this board?
Can someone post some SS of anything this board can do...someone said they got 215 bclk...that's a good first indication and the board is still on initial bios...if someone can do over 220 bclk passing linx, I'm sold.
Patience! :D This is a brand new mobo with initial BIOS.
After one day I can say, that this P6T7 is rock solid and that the CPU needs 0.08 VCore less as on my RIIE and that is very very good!
Furthermore, the system boots much faster than with RIIE, there is no cold boot issue (in my case) and the overall performance feels better (smooth, no lag) while loading programs and playing games.
This evening I will run Vantage to compare the P6T7 with my RIIE.
The only two things that concerns me are max BCLK and the heat (shows 57C but feels much hotter???, but hey, it is stable!!) of the NF200. In case of the max BCLK I’m sure that new BIOS releases will fix this!
For all my Tests I'm using exactly (switchting from one mobo to the other) the same CPU and Memory as on my RIIE!
Best wishes!
nice board :)
so what is the max BCLK so far?
Does S3 Resume work on this board?
Hi nge769
This are the stable BIOS settings:
http://www.abload.de/thumb/bios010h2f.jpg
http://www.abload.de/thumb/bios02aipw.jpg
http://www.abload.de/thumb/bios034c89.jpg
http://www.abload.de/thumb/bios04_membc2s.jpg
Cheers
FAAAASTer!! :D
Who wont believe nge769?? ;)
I did every Vantage Test three times, with same drivers, same OS and same Hardware, for each mobo.
Here I present you the Result:
ASUS RIIE with slightly higher overclocking!
http://www.abload.de/thumb/riievanta...toffsl5rg4.png
ASUS P6T7 WS SuperComputer
http://www.abload.de/thumb/p6t7vanta...toffslwuuq.png
I'm relay impressed by this piece of Hardware!!
what´s now the max BCLK? can ther P6T7 perform like the classified?
Thanks Crash, your the man;):up:
Here is your settings on my board..But i had to up Vcore,QPI,mem just to play it safe(I have I7 975 Batch 3851A333:shakes: wanna trade :rolleyes:)
http://img26.imageshack.us/img26/5773/44gig.jpg
The thing that impressed me the most was the Temps:shocked:
http://img526.imageshack.us/img526/3732/44gcstemp.jpg
Thats right , those temps on CS\NB are with prime95 and vantage , and that was my main concern,Not anymore:up::up:..
BTW, crash you need some air conditioning in that room!! :yepp: I guarantee
you'll drop 10 to 15c on your CS:)
Thank you for this Test!!
I think if the days are becomming colder then my Temps shuld be around the same as yours.
Yesterday late in the evening I hab 23C room and the Sensor shows me 47C on load.
One Question I have. If you touch the HS, feels it much warmer than 40C? Mine feels like 70-80C at 50C Sensor. But this are only my feelings and must not be right.
Found out, that above 214BCLK this Mobo needs very high QPI Voltage, but as I said, we must wait for a new BIOS.
Thank's again. Cheers!
When i touch my heatsink its barely even warm (cool sometimes)I have good air flow.
Ive experimented with different configurations , fans ,what i ended up with was i changed my front fan too COOLER MASTER R4-L2R-20AC-GP 120mm and changed rear fan to 140x25mm 1600rpm 80cfm, with very low noise.
before that, i tried putting fan on bottom of case next to psu with bad results. i had better results with (jetstream) front bottom intake ,back exhaust, from right to left.I noticed your pump and no intake fan on front bottom of case, just bottom fan that looks like it blows out quickly through
top of case , leaving hot spots.
For 7c difference, i don't know if its worth changing things, thats your call.
For me , its the most important part of my set up.
BTW, look in your bios and tell me your system temp, I'm curious , mine is 35c
Kinda odd that his is hot and yours is cool. Is yours getting good transfer (ie mounted well)?
Well I finally decided to go ahead and purchase one of these last night to test out. I haven't opened my Classified 760 yet so I'm thinking about selling it and keeping the Asus. I wish nge769 would quit babying that $1,000 975 XE though and see what kind of max BCLK he can get haha ;).
