Another one waiting for more reviews.....its talks the talk, but can it walk the walk!?
http://healthhabits.files.wordpress....ainobvious.jpg
:D:D
"Κοντός ψαλμός αληλούια" <---(that means, we are going to find out soon...:)
I wonder: when plugging in the 3 pin into the cpu 3 pin fan does the pump become voltage controllable? Or do we need to set the pump to be always 12v for 3 pin cpu?
Oh sweet thanks. Also I wonder if we can add another 120 fan to make push/pull.
It have been said that it is not the same Asetek cooler but an improved one. I think it was around 20% improvement :)
I'm just worried about the alu+copper.
Well those are pretty old reviews and I wont go by that, but this looks like somethign I would like to buy if the reviews are good.
+1
99.9% sure they wont go with just water setup and that they will have their own concoction of liquids to use in the kit ;)
from the looks of the pic's on hexus you can (y) 120mm mounting holes on both sides, I reckon this + two s-flexes 1600 will be pretty snazzy for under £70
I'm all for this type of stuff...make water cooling kits easy and tons of people will buy them. Corsair is a great company, so I have faith that the H50 will pretty much be awesome.
rad can be push-pulled?
+1 they said they have tweaked the design etc...
same as above.. they tweaked the design and mentioned by a poster it was in the region of a 20% better performance
yes can tell by the pix on hexus
they did =) your correct..
Red beard
MOAR info please :
whens this coming out...
i found some nice pics on techreport of the H50 in their new case...it's funny, it's pretty much the exact system I want to get next (not counting mobo and lack of sound card)
http://techreport.com/discussions.x/17014
If it wasnt copper+alu i'd probably pick one or two up.. :(
wow that setup is too clean, people will think your broke and cant afford a whole computer
Hmm... Not sure but here is a hands on at computex.
http://www.xcpus.com/reviews/163-Cor...09-Page-2.aspx
"The H50 is Corsairs high performance CPU cooler. It is a maintenance free water cooling setup similar to the Cool IT Domino. The difference is that Corsair seems to have created a solution able to cool an overclocked Core i7 processor enough to top the TRUE 120 at the same settings. We were witness to two identical systems, save for the CPU coolers. System 1 used a TRUE 120, system 2 had Corsairs H50. The H50 was able to cool the i7 975 by 15C more than the TRUE 120 with Prime95 running 8 threads. That is really impressive for this type of water cooling setup and to make it even sweeter, the retail price is going to be around $79 in the US. Look for our review once samples are available."
Hopefully it is this good.
I see smaller heat-exchangers in the future going along with smaller NM,s .
http://www.frozencpu.com/products/91...M3_CWCH50.html
85$
I wonder: is it possible to say get a small reservoir and install it into the loop? This way any water evaporation will not be a problem. Or is the system under pressure and will not function properly if you disconnect it?
