It's been over a month since the last post. How is the build coming? Any timeline on when you think you will be able to complete this awesome task?!
Waaw xD it’s a long time ago since I posted an update !
Well, XS is not the only one … I have been busy for school and other stuff … so I didn’t have a lot of time to mod.
But – here I am back again, with lots of pictures and info
It’s time for a huge UPDATE !!! Elements of Fortune !!!
In the beginning of august, I bought some new tools for a good price.
http://i183.photobucket.com/albums/x...2/DSC07456.jpg
http://i183.photobucket.com/albums/x...2/DSC07455.jpg
http://i183.photobucket.com/albums/x...2/DSC07449.jpg
http://i183.photobucket.com/albums/x...2/DSC07450.jpg
http://i183.photobucket.com/albums/x...2/DSC07451.jpg
http://i183.photobucket.com/albums/x...2/DSC07452.jpg
There goes my money :P blahblah, I’m happy ! At least I got some good quality tools now ;)
I also made some orders in China for LEDs and electronics, and I got some very nice stuff from MDPC-x.
And because pictures say more than 1000 words : tadaa
The package from China
http://i183.photobucket.com/albums/x...2/DSC07589.jpg
http://i183.photobucket.com/albums/x...2/DSC07591.jpg
http://i183.photobucket.com/albums/x...2/DSC07595.jpg
http://i183.photobucket.com/albums/x...2/DSC07597.jpg
PSUs
http://i183.photobucket.com/albums/x...2/DSC07596.jpg
Little motors
And for these things, I also made a “cabinet” ? Well I mean a thing to store things :P
http://i183.photobucket.com/albums/x...2/DSC07582.jpg
http://i183.photobucket.com/albums/x...2/DSC07614.jpg
Kinda WaW huh !? :P This cabinet will be empty once I finished this mod ;)
And then another package from Germany…
http://i183.photobucket.com/albums/x...2/DSC07258.jpg
http://i183.photobucket.com/albums/x...2/DSC07264.jpg
http://i183.photobucket.com/albums/x...2/DSC07260.jpg
http://i183.photobucket.com/albums/x...2/DSC07263.jpg
Now this is quality stuff :o !! amazing
I will sleeve this 1200W PSU from BeQuiet and all the other cables that will be visible inside the project.
http://i183.photobucket.com/albums/x...2/DSC07357.jpg
-- aye – now all eyes back to the case
We continue from here:
http://i183.photobucket.com/albums/x...2/DSC06897.jpg
Still remember it? Here we go
I continued with the bottom side of the case, the part where the hardware will fit in.
http://i183.photobucket.com/albums/x...2/DSC06952.jpg
Before that, I had no idea what colors I would be using. But when buying the sleeving and LEDs, I made a decision.
Colors will be: Black, white, orange and aluminum
The hardware components will be black/ orange / the cable-sleeving as well. :)
So I needed to find a color for the background … White !
To make a good white (and not gray looking background) I bought some white acrylic. Behind that white acrylic, I will use small White LEDs to give it a cool look.
Placing of the LEDs
http://i183.photobucket.com/albums/x...2/DSC06953.jpg
Started to soldering
http://i183.photobucket.com/albums/x...2/DSC06955.jpg
http://i183.photobucket.com/albums/x...2/DSC06961.jpg
http://i183.photobucket.com/albums/x...2/DSC06958.jpg
http://i183.photobucket.com/albums/x...2/DSC06962.jpg
It’s still a dark look, so let’s begin with making the acrylic.
http://i183.photobucket.com/albums/x...2/DSC07359.jpg
http://i183.photobucket.com/albums/x...2/DSC07361.jpg
http://i183.photobucket.com/albums/x...2/DSC07368.jpg
It looks great when because it has a good contrast with the hardware ;)
http://i183.photobucket.com/albums/x...2/DSC07365.jpg
I’m not really satisfied with the result, So I will also make LEDs in the bottom.
http://i183.photobucket.com/albums/x...2/DSC07653.jpg
http://i183.photobucket.com/albums/x...2/DSC07652.jpg
Don’t mind the rusty look, it will be painted :D
Without acrylic
http://i183.photobucket.com/albums/x...2/DSC07659.jpg
With
http://i183.photobucket.com/albums/x...2/DSC07660.jpg
Still looks a bit dark on the right side… that is because the background is black. I tested the difference with a white sheet of paper. Much better ;)
http://i183.photobucket.com/albums/x...2/DSC07664.jpg
http://i183.photobucket.com/albums/x...2/DSC07667.jpg
But I’m not going to use paper … aluminum is a better quality material. And I will paint it white in the future.
http://i183.photobucket.com/albums/x...2/DSC07685.jpg
http://i183.photobucket.com/albums/x...2/DSC07687.jpg
I used small bolts most of the places. Because they would dim the small LEDs.
http://i183.photobucket.com/albums/x...2/DSC07693.jpg
The other ones I gave a smooth finish :P
http://i183.photobucket.com/albums/x...2/DSC07740.jpg
Meanwhile I also worked on the struts beneath the hardware layer.
Remember these?
http://i183.photobucket.com/albums/x...2/DSC06965.jpg
They will be blue – started with soldering
http://i183.photobucket.com/albums/x...2/DSC07623.jpg
http://i183.photobucket.com/albums/x...2/DSC07615.jpg
http://i183.photobucket.com/albums/x...2/DSC07626.jpg
http://i183.photobucket.com/albums/x...2/DSC07630.jpg
Still needs a lot of work, but this is the goal:
http://i183.photobucket.com/albums/x...2/DSC07629.jpg
http://i183.photobucket.com/albums/x...2/DSC07639.jpg
The UV LEDs on top are fitted on the bottom plate. Ready and steady ^^
http://i183.photobucket.com/albums/x...2/DSC07643.jpg
UV power ! Perfect angle for that eye-candy reservoir. (It doesn’t shine everywhere, only where needed)
http://i183.photobucket.com/albums/x...2/DSC07642.jpg
http://i183.photobucket.com/albums/x...2/DSC07646.jpg
The eye-candy reservoir needs to look cool and shiny. After a while I decided not the use aluminum foil but a sheet of aluminum. This will be polished ;)
http://i183.photobucket.com/albums/x...2/DSC07682.jpg
http://i183.photobucket.com/albums/x...2/DSC07683.jpg
http://i183.photobucket.com/albums/x...2/DSC07684.jpg
So I started working again with the white acrylic.
http://i183.photobucket.com/albums/x...2/DSC07733.jpg
If you take a good look, you will see that I made place for the power supply unit.
http://i183.photobucket.com/albums/x...2/DSC07726.jpg
http://i183.photobucket.com/albums/x...2/DSC07727.jpg
Whoooo that’s a close one! But it works ;) :)
http://i183.photobucket.com/albums/x...2/DSC07730.jpg
http://i183.photobucket.com/albums/x...2/DSC07741.jpg
http://i183.photobucket.com/albums/x...2/DSC07742.jpg
After filing and sanding …Looks good huh?
http://i183.photobucket.com/albums/x...2/DSC07744.jpg
Aye, another bend
http://i183.photobucket.com/albums/x...2/DSC07745.jpg
http://i183.photobucket.com/albums/x...2/DSC07747.jpg
Yuppie, I made it ! :P me looking very happy because working with the acrylic is a tough job. But I’m starting to learning it ^^
http://i183.photobucket.com/albums/x...2/DSC07754.jpg
http://i183.photobucket.com/albums/x...2/DSC07757.jpg
But here we go again :P a small problem …
http://i183.photobucket.com/albums/x...2/DSC07760.jpg
The power supply cable is a little bit bigger because it is a 1200W PSU…
ARGH !!!
http://i183.photobucket.com/albums/x...2/DSC07761.jpg
I mailed to BeQuiet for finding a nice solution… If there isn’t a solution, I’ll make one myself :D
- make a 90° angle in the cable
- or make a gap in the frame so the cable would fit
- maybe something else I could do ? hmm
Well – more coming soon ;)
I think I continue working on the hard drive casings, and continue with the white acrylic.
cheers
Tom
i think there are 90 degree power cables, i've seem some weird cases that use them for placing the psu on the front. Other option is to make a custom powercable, possibly with thicker wire and sleeving. nice mod, really cool!
yeah Junim,
90º power cables are easy to find and would solve this.
http://www.americanmusical.com/Produ...arge/49800.jpg
