OK, now I get it (hei, didn't I say that before? :rofl::rofl::rofl: ). Still, the only thing you want is the best flow rate possible...and to get that you need to know how restrictive is your loop in order to know how pressure differencial will affect the flow rate in your loop because, as you said (and that was the thing that I was missing since the beginning), flow rate, althought constant throughout the hole loop, varies depending on your loop (elbows, blocks, etc) and this is where pressure head matters.
Thanks again, you should consider at all to put some of this to some of the stickies because although there is most of it, there are some missing points that are asked once and again and again yet there is no place to be referred to in order to know them. But hey, it's nice to know that you could ask it knowing that no matter how many zillions time it has been posted before, you will get a reasonable answer :D
If anything that has been written is correct (which I believe unless proven wrong) is that the only thing in which the order of the loop matters is when:Quote:
Originally Posted by nikhsub1
a) You make the loop shorter (without putting elbows nor other stuff that may add restriction) so there is less pressure drop and thus you get more flow rate (so, more performance)
b) You put the rad after the pump...but here the only difference will be that the pumps heat will be transferred before it gets into the loop...but thats something negligible because it's just a few watts, don't think It's going to make any difference.
If you've got a certain loop, the only way to improve it's cooling capabilities are:
a) Reducing pressure drops (re-routing the tubing so you don't need elbows and such things)
b) Improving the pumping capacities.
As what gives more performance in a block is the "speed" of the water (which depends on the flow only), the place in which you've got the highest pressure drop just doesn't matter at all because pressure accounts as a hole.
