awesome clocks and 06 score riska!! i wish i could do that on my 4770s
only catalyst 9.5 & smartdoc combination work to raise vgpu on both card in my case...no way with cata 9.7 or 9.8....
in my case, yes! no way to "clock" both card (vgpu) with cat 9.7/9.8!
But there is another condition: i have to use an asus mb (maximus 2gene) because it does not work with my DFI JR P45...
on max 2 gene + cat 9.5 : i only have to apply the vgpu w/smartdoctor once for all to raise both vgpu!!!
so ocing both cards work up to 935 @1.225 using smartdoc but not @1000 for both card!
Weird issue...:confused:
i suppose you have a good PSU
nice it solves your issue...
What model hd4770 video card can change the memory and GPU frequencies with low voltage and change bios (asus top bios) but with native HDMI ? I want to buy a video card hd4770
Hi,
Does anyone know what would be safe voltages (vGPU) to use for a 24/7 full load overclock ?
I'm running 1000/850@1.1v using an after market cooler.
GPU temp is 50C mem 54C Shader 56C
Many thanks in advance
OK Thanks, I just wasn't sure if the standard baseline was 0.9 or 1.0v, it's a lot different to CPU overclocking ;) I was just very surprised that whatever clock I hit it stuck - no errors :eek: Which got me thinking that maybe I'm pushing to many volts through it. I guess not then ;)
Yes the BIOS looks like being the Asus TOP as downloaded through these forums. If you have any other recommendations let me know.
Card is a bog standard reference 4770 branded VTX.
http://gpuz.techpowerup.com/10/01/29/7aw.png
