With the right voltage and the right settings in driver and clocks in 2d/3d in bios they kick ass...
http://www.hwbot.org/result.do?resultId=880242
look at the gpu score
I have HD 4770 version where are missing few MOSFET and capatitators. Are there any diference in OC performance?
And what, if I buy exsact mosfet and capatitators, will be something differnet?
They are all missing the mosfets and capasitors
Awesome score man! What are those driver settings you are using? I've been playing with my 4770 on 3dmark06, unlike you I can't get close to the i7's on total score. My best so far is 18453 at 1025/1225.
Use all set to performence and ccc AI disable and then you have to try different voltage for the gpu it helps and try running vantage
I can't get anywhere near your vantage gpu score...
I've tried all I can think of. I set all the gpu bios settings to 1g/1.2g in rbe and run my phem II x4 at 3.8g. Regardless of CCC settings I always seem to come out around 9300 on my gpu score. This seems to be approximately the same score everyone else is getting on hwbot. Have you tried running 3dmark06?
I finaly make vmod and I wanna ask you what are max V for vgpu an vmem?
Up to what point I can raise the voltage safely? Now I got 1000 mhz on gpu (watercolling) with 1.160 vcore, but my card be more, I think...
You can go for vgpu = 1.35V more you can't becouse the card have over-current protection.
1Ghz on 1.16V? Does it work in 3Dmark 06 and other test programs?
If u use asus smartdoctor to go for 1.3v then u can use hardmod to go up to 1.65v
my 5 cards can do 1000mhz at 1.15v 3d01-3d03-3d05-3d06-vantage stable
How can you get to 1.65V? I have saphire 4770 and voltmod for gpu and mem(hardmod) but if i set vgpu over 1.35V the card turn off.
gddr5 must run on 1Ghz at stock voltages too, becouse as I know this ram is made to run on 1ghz.
Look at my post if you use asus smartdoctor and set the voltage with software to 1.3v then you use hardmod to go higher..
you have to have the card flashed with asus topbios
Aha, thanks, will try to flash and will see.
Hi guys, I would like to know if someone managed to overclock with rivatuner without disabling SmartDoctor voltage regulation? When I use RT, the voltage goes back to stock value (1v) and It's quite disappointing. The card can run 3d mark 06 @ 970mhz core with defaut voltage, which seems to be a good result and is, of course, stable @1Ghz with 1.1v (CCC will work with SmartDoctor but won't go over 1GHZ :(). I don't want do make hard mod for now if soft solution exists (it seems like Riska managed to make them work together)
Just minimize smartdoctor to tray and it should work but it works also if you close asus smartdoctor but you have to press ok to set voltage and mhz
Thx, in fact this was working, but the card seems to have limit around 1ghz, because it won't do more than 1060 @ 1.3v when it is able to run 970mhz at only 1v :(
Did you do anything special to run that high with yours? (1225 is a great result :D). Maybe have you got the press release version?
No got the retail version but modded it my self to the press release version + some more mods and i am using standart watersetup to cool the card and it never goes over 50c with 1.61v
I recive 2nd card 4770 but this one have BLUE PCB and vgpu controler isn't the same as on card with red pcb. Any sugestion about hard volt mod?
few bad pics
http://www.shrani.si/t/2Y/OZ/1ncMBnUn/091109182135.jpg
http://www.shrani.si/t/1/tm/SIyEU2o/1/091109182203.jpg
http://www.shrani.si/t/1X/l9/1Clr6BWc/091109182259.jpg
http://www.shrani.si/t/3G/fr/1Lz8moi5/091109182317.jpg
We need better pics!!
I agree, but even with eyes I can see what no. is on chips.
Well, I think this one is for sure for vmem. It have 4.98kohm on ?3-7?pin
http://www.shrani.si/t/1O/M9/mUdUlKA/120920091147.jpg
http://www.shrani.si/t/2q/3X/4WelN9MR/120920091153.jpg
http://www.shrani.si/t/1C/Js/4uhhN9qh/120920091154.jpg
Else, tomorrow will try to read what is wrote on the chip.
pal, uP6201BQ ?
Measure resistance between pin 13 and 4(or any GND).
Yes, it isuP6201BQ and pin FB to GND is 3.30Kohm.
EDIT: Can I flash this card with Asus TOP bios and then try with SmartDoctor. Will it work fine?
