I was just joking.. :D
Heatsink for memory? Usually not needed but depends whats on HD 4830.. DDR3?
Did a run with a sapphire 4830 yesterday on dice. first test with 1.55v vgpu and 950/1280 flew past. No problems, had some trouble with my cpu after so i didnt have time to test more :(
Getting a waterblock this week for it :) How much voltage is safe for 24/7 use? Will the vrm's take dmg from to high voltage or what would happend?
If you have watercooled VRM, no need to worry I think.. should survive like 1.6-1.7V maybe.. 24/7.. hm probably something that allow you OC high and keep temps low or average? :) Only problem with voltage is electron migration and thats caused by high temperature and high voltage.. so if you keep temperature ok, no need to worry.. at least it works for CPUs. :)
How i can OC more with CCC ?
It only can make 700MHz max to core :(
Download Radeon Bios Editor from techpowerup.com and look into Aditional features, theres way of increasing OC in CCC. Tough, useless for my HD 3870. :D
Yes, I bios mod my 8800GT about year ago. I liked it, core 600MHz => ~745MHz
Shader 1500=>1800MHz and mem stock v 1800=>2250Mhz 24/7 :p:
I will now mod my HD4830 bios, first time mod ATI :rolleyes:
I am not sure about the 2D clocks, i mean, will it work, so i dont touch them.
lol :rofl:
http://www.aijaa.com/v.php?i=4387148.jpg
http://www.aijaa.com/v.php?i=4387142.jpg
http://www.aijaa.com/v.php?i=4387144.jpg
http://www.aijaa.com/v.php?i=4387145.jpg
wtf :confused:
Windows can't find drivers, i already try re-install drivers but no.
I did flash the card in windows..i didn't find instruction how DOS :shrug:
But i don't think thats the problem, i will try now XFX own bios.
e.
Aww..http://www.aijaa.com/v.php?i=4387142.jpg
DON'T touch that :)
