Try setting it like 102-104 :up:
c1's can play as well :ROTF:
http://valid.canardpc.com/show_oc.php?id=554513
These boards are amazing.
Awesome!!!! :rocker::rocker::rocker::rocker::rocker::rocker:
amazing cpu/mobo combo, congrats :)
Here you go kenny,
http://img521.imageshack.us/img521/4189/94965285.jpg
Excellent PP Raja! Congrats on WR :D
Thx to OPB for the tips. Not maxxed out yet, but getting better...
244?! it's incredible...this board really rocks ;)
congrats man! ;)
Astonishing run there Raja :up: Congratulations, keep it up buddy ;)
keep pushing it
Come one, "smack that :banana::banana::banana::banana::banana:"
Nice results;)
Impressive raju :up:
Started playing bclk game here meself tonight. 2/8 divider and 8-8-8 seems to be the sweetspot, exact same settings cannot boot 2/6 9-9-9 :confused: Multi 19 max for now, 20+1 is a lot harder. On air. VTT can be lowerd. Any tips ? :D
http://img.photobucket.com/albums/v2...920/156687.jpg
http://valid.canardpc.com/show_oc.php?id=557288
Probably needs to be cold to really scale..
254BLCK... :eek:
what are you tweaking to hit these kind of levels raju? Im not getting as much time to play around with my bench setup as I wish I was this week :(
Cooling is cascade - evap around -111.
regards
Raja
are you using sub zero for the mobo also? how is it possible to make bclk scream like that??
Board is cooled by ambient air only - room temp 16 Celsius. Just the CPU on cascade.
regards
Raja
very nice,
could you post the trick you gave to OPB ?
congrats again
there is no trick to it, just overclocking. same principles that i've been using since the RE. adjust skews, play with voltage combination's, add cold. Kevin fired me his settings a while ago and it was pretty much what i had, now with a 920 D0 i am cranking out 250 BCLK validations quite easily.
learn the board and see what works for your CPU
