Meh i take down EVA tomorrow. :P
:confused: tell that to the 3d guys :p:
Or the XSfah guys, or any folder/gpu grid'er or idk what else runs on the gpu right now :up:
Think you'll find the quest for stability on max clocks a very hard one, certainly since 3d stable != folding stable, not by a long shot. And currently there is no folding gpu test available, like you have gromacs based cpu burn in tests.. No way to be really certain the odd EUE you will always get is because of the WU itself or the overclock. Some wu's will EUE on all systems, stock overclocked or downclocked to a crawl, and only on 'statistics' you can 'determine' if a gpu is really stable for f@h ( eg, you get more eue's then statistically is to be expected then it's 'probably' hardware related ).
There is a cuda memtest in Occt, but it's only ram test not shader intensive. Got to wait till the guys from Stanford release one :(
aye Naekuh that statement is 100% false. lower temps equals lower resistance in the GPU and higher clocks, there's a reason you cant have 50 radiators on a GPU loop and get to LN2 clocks on a video card.
for a better technical reference see here http://www.xtremesystems.org/forums/...d.php?t=215832
I wish I could take my card to 1000mhz like the LN2 records :( but alas that is not possible even with my means ;)
Sub'd; looking forward to this!
Sorry guys my camera battery died, so its recharging.
I started disassembly of Eva, im still waiting on my eVGA board to do final disassembly.
Then i'll test the evga board, and then go on final disassembly.
UGH, its harder taking apart a h2o computer then building one. :\
ummm, don't take it apart just get all new toys!!! Duh!
It's always sad to take one apart, but this is going to be good. A new Queen in the house!
eVGA board finally arrived.
Gonna throw her on a rack and post then do final disassembly.
