LT uses Delrin, so no... you can't nickel plate it.
Also... I am begging for some temp numbers. Even really sketchy ones, I am curious to see how it compares to other blocks in a high flow setup.
Pics of the inside?
could someone open one of these up so we can see what the internals look like?
Thankee
If there are any left :P
I ordered mine friday night & should be getting it tomorrow since sidewinder is so close to my home
There are already pictures of the fin design, use google to find them.
Some internal shots in this link:
http://translate.google.com/translat...istory_state0=
To those that have them and have seen the inside what is your gut feeing on these? Better then a koolance 350?
Man I'm really thinking of buying this block now. Even if it doesn't fit 16mm compression fittings. I may just go with 1/2" barbs with 7/16 tubing.
I could've sworn I've seen some temps for this block. I'm pretty sure it did better than the koolance 350 block. I can't support this for sure, but just the other day I was reading a forum and it was comparing the koolance 350, heatkiller 3.0, ek supreme lt, and d-tek v2. I'll see if I can find it.
Yep found it, http://www.xtremesystems.org/forums/...ight=hondacity
Certainly much better looking than those FUGLY Koolance blocks.
the best block ya can get atm !
http://www.abload.de/img/img_6190qf8o.jpg
http://www.abload.de/img/img_6193piiw.jpg
http://www.abload.de/img/img_6201ph49.jpg
http://www.abload.de/img/img_6210cklz.jpg
http://www.abload.de/img/img_6211nhcj.jpg
http://www.abload.de/img/img_6233kmn5.jpg
http://www.abload.de/img/img_57414n2a.jpg
http://www.abload.de/img/img_57518iq1.jpg
http://www.abload.de/img/img_5892zhe6.jpg
http://www.abload.de/img/img_55333e1i.jpg
http://www.abload.de/img/img_5543lm8c.jpg
http://www.abload.de/img/img_55522d6u.jpg
http://www.abload.de/img/img_5562rll6.jpg
http://www.abload.de/img/img_5582llla.jpg
http://www.abload.de/img/img_66431kiu.jpg
http://www.abload.de/img/img_66912nxh.jpg
http://www.abload.de/img/img_66995myl.jpg
Damn! That nickel plated block looks very good. Great pictures Bundymania.
yeah and check the last picture with special version of the logo plate - only available direct at watercool.de , because you have to mount the block vertically at gigabyte S1366 Boards.
http://www.abload.de/img/cpu-wasser2zrfv.jpg
http://www.overclockingstation.de/showthread.php?t=3514
i wonder how the mounting mechanism works...that stud in between the mobo and waterblock seem i dunno...:confused:
..to bring light in the darkness -> here is the manual :D
http://www.watercool.de/_uploads/Fil...0_A5_(GER).pdf
Man, I really can't decide now, Suprem LT, K-350, HK 3.0........:(
if the race starts between those 3 little fellas, i personally would prefer the Heatkiller 3.0...the CU Version of course and than you have to nickel plate it asap :)
http://www.abload.de/img/img_6816cws3.jpg
yep, the company where the block was nickel plated did that job for me
no one has any results yet??? I want one.
i'll be testing this block this coming weekend ...i'll be curious how it performs against the k350 and the supremes...
