Are there any USA shops that carry a DFI PWM block in stock?
I've been looking for one on my X48, but I don't want to order over seas.
Thanks!
Martin
Thanks!
Martin
I ordered mine from Germany a 1.5 year ago, in time when I had DFI X38
also I'd like to say that this block is quite restrictive, whirlpool in res becomes noticable smaller
EK-Mosfet DFI UT - Acetalhttp://www.performance-pcs.com/catal...ducts_id=24819Quote:
Supproted motherboards:
- DFI LANPARTY UT X48 T2R
Mosfet and chipset blocks are more restrictive than you would initially think. You're dealing with small channels and a tight space. Here is the ongoing pressure drop chart for chipset and mosfet blocks...
http://skinneelabs.com/Chipset/chips...redrop-gpm.jpg
http://skinneelabs.com/Chipset/chips...redrop-lph.jpg
watercool heatkiller sw-16 tested
and it passed perfect with t3eh8
http://s46.radikal.ru/i113/0908/c9/62fa1e1333a9.jpg
I'm trying to get this top cut for my P35 DFI LP board:
http://img180.imageshack.us/img180/4...ipomtop.th.jpg
It's a replacement top for the DD MPC multi option NB block - allows hard mount and compression fittings.
Just need to print a 1:1 version out on card and test fit before going a head next week. Not sure if the mounting holes are the same as the X58 but I believe the P35/X38/X48 had the same spacing.. so.
dunno if your still lookin but i got mine from performance pc's
http://content.imagesocket.com/thumbs/comp3ea3.jpg
Does somebody know if this one fits Dfi Thr8: HEATKILLER® NB Rev2.1 4-Ösen
http://www.performance-pcs.com/catal...ducts_id=25616
Heatkiller NBS-12a is ok but not 12
only 12a for NB
EK-NB S-MAX fitted on the T3eH8:
http://i377.photobucket.com/albums/o...alokuva722.jpg
CPU-EK-Supreme LT, PWM-Mips MCH2149 v.2, NB-MCW30, SB-Mips MCH2013.
http://img42.imageshack.us/img42/9295/p9032246.th.jpg
duniek how much for that :) ?
clever move by XSPC..:up:
aiming DFI UT X58 for the first full block board, when big LC vendor doesn't make full block for it...
incredibely it came out with great price too, way to go XSPC :up:
can this XSPC UT X58 chipset wb used on DK X58 series as well? it doesn't give any documentation either it can be fit or not. ;)
UT x58 VRM:
http://img709.imageshack.us/img709/3...23x1024.th.jpg http://img709.imageshack.us/img709/6...28x1024.th.jpg
http://img709.imageshack.us/img709/8...35x1024.th.jpg http://img709.imageshack.us/img709/5...36x1024.th.jpg
http://img709.imageshack.us/img709/3...43x1024.th.jpg http://img709.imageshack.us/img709/1...44x1024.th.jpg
http://img710.imageshack.us/img710/4...52x1024.th.jpg http://img710.imageshack.us/img710/1...54x1024.th.jpg
http://img710.imageshack.us/img710/4...57x1024.th.jpg http://img710.imageshack.us/img710/2...58x1024.th.jpg
http://img707.imageshack.us/img707/6...60x1024.th.jpg http://img707.imageshack.us/img707/7...01x1024.th.jpg
http://img707.imageshack.us/img707/2...97x1024.th.jpg http://img707.imageshack.us/img707/9...00x1024.th.jpg
http://img709.imageshack.us/img709/9...20x1024.th.jpg http://img707.imageshack.us/img707/7...ftx1024.th.jpg
http://img203.imageshack.us/img203/2...0htlinx.th.png
i am selling MIPS PWM DFI T3eh8 Nickel Pom Limited Edition
if somebody wants it i can give away for 25 euros+shipping
cartago, might I suggest PM'ing Duniek about sales, instead of posting questions about that in this thread ;). Also, I think the mods would appreciate it if you talked English only in these forums, it makes their job so much easier :).
He asked how much does it cost, where could he buy it and if duniek makes it on his own.
you have two very sry, will not come back before promised
