I only have one boreas.
I have been thinking about adding a 2nd and putting them in series but there is complications - this from the (most helpful) folks at coolit -
""So I have some questions -
1. Can I take the little metal shelf off the side of the boreas w/o disrupting the tec and water block below it? See picture above. Do I need to be careful backing off the bolts and retightening?
2. Perhaps this is an obvious question - is two Boreas better than one? I'm thinking about putting two Boreas in series just prior to the cpu block.
3. Has anyone tried this before?
4. Can you use one mtec controller to use two Boreas to cool one cpu?
5. Where can I get just the barebones Boreas - meaning no mtec, no pump and no block?
6. The Boreas barebones would need to include the cabling to connect the Boreas to the mtec controller.
Thanks ahead of time for your help.
Alllrighty then...
1. The 'feet' for the Boreas aren't attached to anything important so yes you can take them off w/ out hurting anything. Keep in mind that its good to have the Boreas off the ground/floor so the fans can pull air through the whole heatsink and not just the top and sides.
2. Two Boreas are better than one. You'll see one of two things... either you can add twice the heat to the loop and maintain the same temps or you will reduce the temps of the loop while keeping the heatload constant. There are some installation intricacies involved.. see below
3. I don't have anyone doing them in series but I have some people doing 1 Boreas on the CPU an another on their 3 GPU's. Yes, they are happy
4. No, two Boreas will pull too much power across the PCB. There are two ways around this:
i) Two MTECs: you can't use two MTEC's at once because the software doesn't know which one to talk to but you create a setpoint for one MTEC (for the boreas you are least concerned about) and then unplug it and it will remember its setting. Then you plug in the other one and use it for temp reporting/control like you normally would. I have a couple of guys who do this with their GPU Boreas, setting a coolant target 15C higher than their idle coolant temp so its quiet when they aren't gaming and cold when they game.
ii) The other options whichs sounds more like what you will do is to just give the second Boreas straight power which means its going to blast all the time. If you want to do this, let us knwo and we'll help you with the power adapter cable you'll need to connect straight to your PSU
5. Direct from coolit - contact shawn.bouvier@coolitsystems.com or jon.stanley@coolitsystems.com
6. well... we'll connect it to something for you
ps. Be concious of your power requirements, each Boreas can pull ~140W at full blast
pss. If you are running more than 5C below ambient, be wary of condensation."
