Originally Posted by
STEvil
Nah, the car analogy has its flaws. It has a point as well, but the car implied by the analogy is a commuter vehicle it seems, not anything meant to tow (or the ability).
A small truck vs large truck towing capacity would make for a better analogy. Both were bought with the capability to tow, but one is meant to tow a heavier load. Both can tow a heavy load but only one can do it "legally" or without sustaining damage from the work load.
That said, when I buy a piece of hardware I expect it to perform to its full advertised level when I want and for the warrantied time period. CPU's and GPU's are not sold as performing at 80% (number from the air) of their maximum performance... in fact there is no documentation provided which states that running your CPU/GPU at maximum performance could damage it and no software provided to tell you if you are going over the limit..
I dont disagree that furmark is a torture test that pushes things to their limit, but I believe it is a disservice to advertise a performance product as such if it is not capable of running at peak performance for its expected life cycle (realistically there will be down/idle time). Furmark is not the only application which can stress a GPU to full or very near full capacity.
