I mentioned the TEC on the V10, the 70watt is a 40mm... Anything worth while is 50mm's... It has tabs that only allow a 40mm TEC to fit. I might take a dremel to these tabs... We will see by the end of tonight.
Tune in for more!
EDIT: There is no way to put a 50mm TEC on that. It just can't fit. The 4 screws that hold the cold plate to the hot plate get covered by the size of my 320 watt 50mm TEC... What is the largest 40mm TEC that money can buy?
