Originally Posted by Kyle Bennet
Beyond that, the confusing performance and terrible board layout is not the only thing worthy of complaint. How Dan got away with a such a good overclocking experience is beyond me. I could not get the board stable at stock CPU speeds with 1066MHz DDR2 memory speeds. The first thing the board did was to hard lock during an aborted Windows install and then require me to reset the CMOS when I had only set it to “optimize defaults.” Watchdog did not function well for me. OS corrupted once during RAM OCing. NVIDIA hard drive manager constantly gave me worthless pop-up balloon warnings. Hotplug SATA worked, HotUNPlug SATA caused me to have to reset the CMOS by hand again to POST. Getting Hybrid Power to work required some hoop jumping that was in no way documented by MSI or NIVIDIA even though they knew what had to be done – and they were active in correcting this on its websites. If you did not shut down the board properly, it would require me power on an off multiple times before I could POST. Wrong Hybrid Power drivers were on the MSI-included disk. Hybrid Power would not turn off for me easily, then just finally did. And last but not least, the board would not successfully run a Crysis benchmark without BSODing.
