D12SL-12's (<600RPM-999RPM)
D12SH-12's (>1000RPM-1800RPM)
DFS123812H (>1800RPM-3000RPM)
Thats my thinking anway...good, bad, indifferent? :shrug:
I took three changes to mean 4 different fans :p:
Yeah, that's a good setup to work with :) Each fan is a 'typical' fan in design, which is also good :)
lol. even martins set up can not be compared to the setup of skinnee. as long as he does not test the TFC and TC rads in the same environemnt the results are not comparable. These results only show the XSPC values compared to old test results with other configuration.
All the talk of paper ruining the finish of the radiators had me a little bit worried but I got my radiator today and am happy to report no problems with my unit as far as finish is concerned.
The radiator was wrapped in like a tissue paper and then in bubble packing and then box. Smells like the high school workshop paint locker, whatever the paint is it sure has a nostalgic smell to it.
Its a beefy little sucker, I just might replace my BI2X with a RX240 sometime down the road.
Martin has used
YATE LOON D12SM12-----------1000 - 1500 RPM
Scythe Ultra Kaze 3000------2000 - 3000 RPM
You in your test have used
Yate Loon D12SH12 and Scythe Ultra Kaze 3000
http://www.yateloon.com/style/conten...=8511&id=38837
It seems that the Yates Loon D12SM12 behaves in different way by the
YATE LOON D12SH12
D12SH12... .2200 RPM 88 CFM 2200/88 = 0,0400
D12SM12... .1650 RPM 70,5 CFM 1650/70,5 = 0,0427
0,0427/0,0400 = 1,0682
1008 RPM of Yate Loon D12SH12 = 1077 RPM of Yate Loon D12SM12 (1008*1,0682)
I don't know if the calculation is correct.
It would be correct if the rpm were proportional to the cfm
Surely the two types of fans have a different behavior.
According to me the Yates Loon D12SH12 are fans diverse from the norm.....(Curved blade).
This makes difficult to compare the data of Martin (MLL) to those of Skinnee (SKL).
I have made this calculation done with the data of Martin and Skinnee..........
Published data:
Thermochill PA120.3 MLL.. RPM =1000 C°/W = 0,0307 (thermal resistance)
XSPC RSX 120 SKL......... RPM =1008 C°/W = 0,0663
Formula to calculate the thermal resistance of 2 XSPC in series:
C°/W two XSPC RX 120 in series = 1/((1/C°W rads A)+(1/C°/W rad B)) = 0,0663 / 2 = 0,03315
Difference C°/W Thermochill PA120.3 - C°/W two XSPC RX 120 in series = 0,0307 - 0,03315 = -0,00245
what multiplied for 200 watts it becomes 0,49 degrees.
Difficulty to believe that to 1000 RPM and 200 watts,
Between a thermochill PA 120.3 and two XSPC in series there is only half degree of difference.
According to me to use more than two types of fans makes the most difficult the test.
Besides the Yate Loon D12SM12 of Martin (min 800 RPM)
a good fan is
Fast Version: Scythe S-FLEX SFF21F (1,600 RPM)
550 RPM > 1590 RPM
http://www.silentpcreview.com/articl...ge5.html#sflex
I have used an software of translation Italian> English.....
I hope that you can understand.
As you know (based on your equations :)), open air airflow scales linearly with RPM....but Yate Loons ratings are (like ~97% of other fans' ratings) wrong to the point that they're incomparable even to themselves.
Basically, as long as Martin and skinnee used extremely similarly designed Yates (which is a fairly large "if" considering the variability of Yates out there :(), their results are comparable from a fan standpoint. A 1500RPM SM = 1500RPM SH so long as they're the same design. :) I think Martin and skinnee conferred when skinnee was setting everything up, so hopefully that was addressed :)
@Skinnee
Nice job anyway :up:
But I´m just waiting for the PA120.3 vs. TFC360 vs. RX360 comparison :D pleeaaase ... ;)
I ordered http://www.tilatech.com/xspcrx360.html and http://www.tilatech.com/xspcrx120.html. Received them last night and no paint problems with mine. Performs great on my second rig with QX9650 at 4.0ghz and a single 280gtx.
Is anybody able to / Will anybody compare the RX360 with PA120.3 or TFC360 on the short term?
This will sum them up :D
Performance will all be very similar
TFC360 will come in nice package and nice paint job with a valve to release liquid.
RX360 cheapest in price terms and decent paint job, bland package and looks
Thermochill will be mid range with different standard fittings, but similar to the other two
these rads will be within 1-2 degrees of eachother because of the same build design
This is all speculation however :D, I'll let the pros do the testing ;)
That is much worse than the production sample I received. I did not expect the paint to be that marred, your reaction and response is completely justified IMO.
Great work Skinnee, very good review!!!
Pretty sure you got the worst of the bunch.. I inspected what I have left and they are all way better shape than yours.. I pulled them from stock anyway and between myself and XSPC we'll figure out whats the best thing to do with them, probably ebay them sooner or later..
I do have a new order in and the next batch of rads are being painted again prior to shipping.. Chinese New year will delay the shipment so no more for probably a few weeks.
If anyone does have one they aren't happy with, just drop me a PM and we can work something out for you. mcoffey you have pm. Skinnee, great review.:up:
Hello,
I have to renew my liquid cooling kit for CPU platform change, from P4 to i7 ...
The kit is to be integrated into the PC case, including radiator, to earn more some degree, but keeping silent!
I think that regardless of Wb, which more than 1 or 2 degrees of difference between one or the other WB's does not give; the most critical point is to improve the radiator.
I thought the TFC Single Radiator 120 and the ultimate XSPC RX120 works well with fans at low speed (1200 rpm es. Noctua, Schyte s-flex, Yate-Loon L), at best price ...
But then I read this test
http://eiskaltmacher.de/portal/index...1079&Itemid=53
where fans with its low-speed 1200 rpm (yate-loon L), soars a radiator for me unknown and much more subtle, and then for me to integrate better in my PC case, the TFC or XSPC RX120 that I had the best working at low speed!
The radiator is this MAGICOOL ELEGANCE COPPER 120
http://a.imagehost.org/t/0992/plexicopper_1.jpg
This is the graph
http://a.imagehost.org/0004/Radiator_Single_12V.png
I think that points to some degree because it's more fully in copper, unlike other copper radiators that have only in the strip, while the entire radiator is painted brass!
What do you think, and suggest to me for the BEST BUY between these three radiators?
- MAGICOOL Elegance copper 120
- Feser-TFC X-Changer 120
- XSPC RX120 :confused:
Thanks a lot
Got a RX360 coming on Tuesday, will be interesting to see whether UK samples have the paint marring..
otherwise looks like a solid performer, amirite? :up:
considered I got mine for £26 I think I'll let it slide if it has :shrug:
