Quite common on more recent AM2 chips (the higher corners)
my 9950 looks the same.. and it is not raised... ;)
http://my.ocworkbench.com/2008/amd/P..._X4-info-1.htm
http://my.ocworkbench.com/2008/amd/P..._X4-info-2.htm
Introduction to Phenom II X4 and Expected launch date of AMD Phenom II Processors
We received news that the expected launch date of the AMD Phenom II processors would be Jan 8 , 2009. Although it is a launch, retail products won't be available till Feb 4, 2009. Pre-orders should take place in from Jan 8 onwards.
The first two models that will appear would be model 920 and model 940. Both are 45nm.
Model 920 is rated 2.8GHz (14x200) and is a Quad Core processor. It has a HT link of 1.8GHz. It will have 256KB L1, 2M L2 and 6M L3 cache.
Model 940 is also quad core and is rated at 3GHz (15x200). it also has a HT LInk of 1.8GHz, 256KB L1, 2M L2 and 6M L3 cache.
http://img216.imageshack.us/img216/6...3dmarkvvx2.jpgQuote:
3DMark Vantage score running on AMD 790FX mainboard
The 3GHz processor is able to churn out impressive performance, scoring P8492 in the 3DMark Vantage test. A similar score can be obtained with a overclocked Core 2 Quad Q6600 at 3.6GHz with ATi Radeon HD 4870
I presume the i940 would be using a 4870 too, if all things were as equal as possible then that aint too bad...
I thought single 4GB sticks were only possible with Registered DDR2. :/
EDIT: Stand corrected. http://www.newegg.com/Product/Produc...82E16820231183
Hmm. If previous SuperPi scores were on 1.8Ghz, upping this is going to look fun.
I reckon it's because of lower L3 not getting in the way of higher clocks, or something similar.
On that screen NB clock is only 1.8GHz. Surely AMD won't go lower than previous BE chips on a brand new core.
Also worth noting is memory setting for that run. DDR2 800 with CL6-6-6!
Looks like this run is crippled in more than one way to not upset too many people for now.
There is an english version in OKTABIT's forum regarding the Phenom II upcoming review. Check it out, several HARD tests will be uploaded soon...:up:
Aye.. there are better scores too.. like this http://service.futuremark.com/result...eResultType=19 Q6600 @ 3GHz but GPU influenced the score. ;)
EDIT: Q9450 @ stock with similar (a bit higher) GPU score http://service.futuremark.com/result...eResultType=19
As far as I see the CPU score is 1306 for test 1.
http://www.sharkyextreme.com/img/200..._vantage_1.jpg
http://images.hardwarecanucks.com/im...arkvantage.jpg
Doesnt really look good for Phenom II.
Seems like the bios does not recognize the CPU in a proper way. I remember 3 GHz Phenom II should have 2.2 Ghz for NB Speeds.Anyway, DDR2 800 and CL6 subtimings sucks :down:
Question: 3dmark06 used to score different between 32 and a 64 BIT OS, does 3dMarkVantage do the same ?
Thanks Face,Quote:
Sounds like another delay here.
