update
Core i7 920 @ 3.9Ghz
BCLK : 195
Multi : x20
ddr3-1560Mhz 9-9-9-24
1.28v Full
(prime95@Blend)
http://img152.imageshack.us/img152/1038/390015be9.jpg
:up:
update
BCLK : 195
Multi : x20
1.28v Full
(prime95@Blend)
:up:
what temps you hitting?
Hi
The Higher Core around 66š
:up:
EDIT:
Just installed new F4K bios
3800Mhz @ 1.20v
BCLK 200
Multi x19
Uncore x16
memory multi x8
QPI/VTT : 1.235v
Vcore : 1.20v LOAD
http://img87.imageshack.us/img87/9391/3800120vev4.jpg
and 220BCLK
http://img184.imageshack.us/img184/5952/220poicwa3.jpg
validation
http://img381.imageshack.us/img381/7872/220tj8.jpg
http://valid.canardpc.com/show_oc.php?id=457815
Very Good Bios :up:
regards
Looks like I have to try a new bios on my extreme as well, since the 8x ram mult isn't working at a BCLK of 200 with either of my 6GB kits.
I've had success with 6GB of Corsair Ram with the F3 and the F4J bios' (what is the plural spelling of the bios?) with a BClk of 200. My settings are very similar to what was shared in this thread. I'm sure you have probably figured it out by now. If not, I'd be more than happy to post my settings.
Nothing to "figure out" really, BCLK of 200 + ram mult of 8 = no post with any of the 6GB kits I tried, regardless of other settings ;)
Need to try new bios.
Update
Bios F4K
191x21
QPi/VTT : 1.235v
Uncore : x16
Ram : x8
Vcore : 1.264v Load
PLL : 1.80v
DDR3-1530mhz 8-8-8-24@ 1T
http://img255.imageshack.us/img255/3271/4ghz126vij4.jpg
regards
Hi again guys
~1 Hour prime95 @ 4Ghz (bios F4k)
191x21
QPi : x36
Uncore : x16
Ram : x8
Vcore : 1.264v/1.28v Load
QPi/VTT : 1.235v
PLL : 1.80v
Vdim : 1.60v
http://img88.imageshack.us/img88/361...estavelga0.jpg
:up:
Hi mascaras,
can you help me? so here is the setup
200x 21 after turbo mode is at 4.2 ghz
i have follow ur setup or try various setting, and bioz is version f3
but after i used the prime95, the speed will go down to 4 ghz.
at coretemp: it sees as 3.8ghz and tdp: just stop 130 watt, when it's full loaded. (147.3 watts idle)
is it my chip?
cheers
oh thx alot mascaras =). i thought my cpu is defective.
Hi guys
tests with F4R bios
Windows Vista 64bit
Core i7 920 @ 3800Mhz @ 1.20v
Corsair XMS3 3GB DDR3-1600Mhz @ 7-7-7-21 @ 1.62v
Everest
http://img244.imageshack.us/img244/2...estnovoyr7.jpg
Cinebench
http://img78.imageshack.us/img78/2663/cineoo7.jpg
22246
And my 24/7 Config
Idle @ 2280Mhz @ 1.04v (Speedstep & C1E)
http://img300.imageshack.us/img300/3564/idleev9.jpg
Load @ 3600Mhz @ 1.12v
http://img156.imageshack.us/img156/3005/3600112viw7.jpg
Regards
i want a i7 waiting for price drop on MB ETC
" Note: You should use the White Ram Slots !!! "
Why we should use White Slots ?
Thanks, Another question :)
I want buy this Mobo for daily usage, is it good ? I see a lot of problem of this mobo :S Strange Noise Problem ( When disable CE in bios, its fine ), Lan Ports Disable Automatically, mobo doesnt recognize 6gb ram Easytune and other programs doesnt run etc. ? Do you have any problem ?
Sorry My Bad English ;)
Depends on the board you get, its usually a coil that beginns to vibrate and makes a high pitched noise. If its to loud just rma it. Theres a risk on every board that it will make noises. But most of the boards wont make a noise.
God damit people should read the damn manual befor playing around... :rolleyes:
Its not a problem, its a feature (which you can disable and should be disabled by default). Its called "Green LAN"
Theres a chance for every board to have certain incompatibilities with certain rams. Just buy some that are known to work with that board. Also use the white slots. :yepp:
that has nothing to do with the board, but more with the thing that gb sucks at making programs that work under vista 64bit. :p:
yep , the only "problem" i have is the Easytune error with Vista 64bit , all the rest work just fine !(no problems so far since 25th november)
best regards
Hey, I will get my i7 setup in a few days. Just wondering some stuff:
1. Is the Gigabyte EX58-Extreme a good choice vs. Asus P6T Deluxe?
Because I happenīt to order the Gigabyte and I hope I donīt gonna miss anything...
2. Can I move a already working RAID 0 array (2x250GB) who was made on a Asus Crosshair to a NEW motherboard without to lose any data?
3. Do you think the 21x enable of multipel are going to be enable to my a good choice vs. Asus P6T Deluxe? Because I happenīt to order the Gigabyte and I hope I donīt gonna miss anything...
4. Can I move a already working RAID 0 array (2x250GB) who was made on a Asus Crosshair to a NEW motherboard without to lose any data?
5. Do you think the 21x enable of multipel are going to be enable to my EX58-Extreme?
6. Is it true that the turbo thing is only the speed of ONE core?
So itīs like, Core 1 = 4200MHz, Core 2 = 4000. Core 3 = 4000, ex.
Exelent work Mascaras, haven't you tried 210BLCK x21 vid under 1.44v with a 3 sticks
at 1600 Cas7 1T, because i belive you have room for mutch higher bandwidth
i would like to see you hitting 20k 21K read test at least.
keep the good work up :up:
cheers mate
