That's a better way of saying what I've been trying to say...
Makes sense... however, you would need to change the entire bottom casing.
Having bei mill a thick peice of alu like that into the shape would cost more then the pump itself. :rofl:
The plastic gets hot anyhow, whats a quick fix, a fan, but a fan looks really ugly by itself.
So the next solution is a sink.
The plastic is kept cooler there fore the internals must be kept cooler. Its a simple idea of physics.
Guys bei is done with my mosfet block.. :wasntme:
Purdy. When's the NDA lifted on the internals?
Edit: No more pictures?
andyc Good explanation.:yepp::toast: above post ^^^^:hm::x
:):up:
The core temp inside the pump motor be higher? Could be very useful in high temp areas. Maybe this heatsink could be appropriate when the pump is put in confined spaces. So this would be usefull>> http://i118.photobucket.com/albums/o...6/DSC00431.jpg
I agree, it's still really creative and cool (superlol), I'm just saying there are plenty of people out there who WILL spend the price of the pump to get an entire bottom machined. Especially if it boosted reliability and lifetime. Then we just need to see Swiftech adopt aftermarket top and bottom ideas, and sell the pump "already good" for less money, since half of it isn't being thrown away... oh wait, thinking in dream-land again.
50,000 hours mean time before failure (MTBF) for DDC 3.2. So what temp does this hold true? 25c or 50c? Can anyone clarify? It would be nice if it would be high so there would be some headroom. So full aluminum bottom maybe a little :explode2: :explode:
:off:
Corsair HX1000W >> Guaranteed to deliver 1000W of continuous power at 50°C
http://www.corsair.com/products/hx1000/default.aspx<<See, Reliability at high temps. Do you guys like Corsair PSU's?
:off:
Yeah, Corsair PSUs are basically amazing. Well, the 620w is...
That 50*C part is one of the reasons I trusted the reliability, I didn't usually see truth in advertising when I was shopping for power supply.
@ mcoffey: Hmmmn... your explanation makes a lot of sense. I'd never thought of it that way before. If you wouldn't mind helping a noob flesh things out a bit - doesn't that reasoning also put the kibosh on any sort of cooling aimed at the external surface of the pump? I've read about guys making sure there's proper airflow around the pump, or even mount fans to blow on the pump (casing). Isn't that all the same principle? Thanks.
thanks:up:
I don't understand what you are saying. The WATER is cooling the pump (primarily? at least SOME, that's what heat dump is). The more the AIR cools those windings, the less heat in the water, less heat to be dispersed by radiator, cooler water through blocks. It's the same principle as the waterblock and radiator.
EDIT or are you agreeing?
I just had trouble running through your sentence. You are agreeing with me. I thought you were saying that the water picking up the heat from the motor, albeit inefficiently, is enough to keep the pump in service. Just me, I guess.
