Update #12 Jan 27 (Rad mount and internal cover)
Yet another updates for ya people :)
Have got a few things sorted. That includes an anti-vibration rad mount, a internal cover and I also got tubing and such delivered.
I think you have got a hang of the process now so I didn't take any photos of the marking and bending. But as you can see i got the cover cut out and bent.
http://www.bandwidth.se/imgs/39/226/img7558.jpg
It is mounted using thumbscrews.
http://www.bandwidth.se/imgs/39/226/img7560.jpg
http://www.bandwidth.se/imgs/39/226/img7562.jpg
I did a little thinking of how to mount the radiator and this is what I came up with.
Got 2x 15mm wide "strips" cut out. And drilled 6mm holes at the ends, in which I put some soft rubber grommets.
http://www.bandwidth.se/imgs/39/226/img7563.jpg
This is how it looks like in close-up (Yeah, it needs some sanding)
http://www.bandwidth.se/imgs/39/226/img7565.jpg
Checked the position of the radiator.
http://www.bandwidth.se/imgs/39/226/img7567.jpg
And bolted it down with some M3 regular screws.
http://www.bandwidth.se/imgs/39/226/img7568.jpg
Tried to mount my yates.
http://www.bandwidth.se/imgs/39/226/img7569.jpg
Countersunk the holes in the plastic frame and mounted the fans with M4 hex cap screws.
http://www.bandwidth.se/imgs/39/226/img7570.jpg
Pretty slick
http://www.bandwidth.se/imgs/39/226/img7571.jpg
http://www.bandwidth.se/imgs/39/226/img7572.jpg
http://www.bandwidth.se/imgs/39/226/img7573.jpg
VIDEO OF RAD MOUNT
http://www.youtube.com/watch?v=RlE0RfHUE8A
