SiSoftware (Sandra) is working on patch also, while their bandwidth numbers are showing about a 40% increase over Everest due to threading optimizations, their latency numbers are almost double what Everest is reporting right now (which I understand Everest is correct in this case) . The latency test in Sandra 2009 puts the X58 about even with the NForce 3. ;)
It is a damned if you do, dammed if you don't situation right now when it comes to reporting memory subsystem results without using an actual application. :D
