this one caused my system to reboot.
Just tried ECS P45T-A, BlackOps, MSI P35Neo2, XBX2 and P5Q-Pro, seems good to me.
Why current Everest versions show too low temps for C2Q CPU´s? As older ones did work fine.
My QX9770 shows 36-48C temps at 4GHz, 1.42V Vcore 9.5 x 421MHz at 100% load, that can´t be right.
Man how many beta versions do they have before a full release?
Oppsss,double post:slash:
Fix some bugs for X58 and Core i7. :clap:
Soon,will implement a new benchmark module in the next (new) version .That will be fully optimized for Core i7.:yepp::toast:
Everest Ultimate Edition 4.60.1566
You're doing stellar works guys with the updates....many thanks!
Lavalys Developer:
:yepp:Quote:
Upgrading is not limited by version numbering. It is only limited by the maintenace/upgrade period. If you're inside that 12 months, then you can upgrade to any EVEREST releases.
Ok stasio, I love to keep my programs up-to-date, specially if its one of those that I use to check stability or benchmarks. However, you keep posting upgrades so fast that I have no time to breath in between!
I guess its all Nehalem bugs right? So I guess I can take a break for now...
