And that's what mine is. I'm working at designing a completely internal watercooling loop for the CPU using a 120.2 rad to fit in my mATX TJ08...and knowing that I could move to DFI's X58 mATX board and pickup a second GTX260 is amazing!!!
DFI LP JR P45-T2R, 10/30 BIOS
575x7.5, Memory 1152MHz
E8600
2x2GB OCZ PC2-9200 Flex II 1050MHz 5-5-5-18
SAPPHIRE 4870
OCZ Core SSD
Orange Slots Used For Memory
click for larger image
http://www.edgeofstability.com/image...ios/main_s.jpg http://www.edgeofstability.com/image...ios/volt_s.jpg
http://www.edgeofstability.com/image...os/dram1_s.jpg http://www.edgeofstability.com/image...os/dram2_s.jpg
http://www.edgeofstability.com/image...s/clock1_s.jpg http://www.edgeofstability.com/image...s/clock2_s.jpg
http://www.edgeofstability.com/image...os/phase_s.jpg http://www.edgeofstability.com/image.../feature_s.jpg
Code:CPU Feature Page
Thermal Management Control................Enabled
PPM(EIST) Mode............................Enabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Auto
Execute Disable Bit.......................Enabled
Virtualization Technology.................Enabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown after AC loss....................Enabled
AC Shutdown free..........................Enabled
O.C. Fail Retry Counter...................1
O.C. Fail CMOS Reload.....................Disabled
CPU Clock Ratio........................... 7.5x
CPU N/2 Ratio.............................Enabled
CPU Clock.................................575 MHz
Boot Up Clock.............................Auto
CPU Clock Amplitude....................... 800mV
CPU Clock0 Skew........................... 200ps
CPU Clock0 Skew........................... 0ps
DRAM Speed................................333/667
PCIE Clock................................100MHz
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Special Add.......................+137.5mV
DRAM Voltage Control......................2.001V
SB Core/CPU PLL Voltage...................1.55V
NB Core Voltage...........................1.4075
CPU VTT Voltage...........................1.26V
VCore Droop Control.......................Enabled
Clockgen Voltage Control..................3.45V
CPU GTL 0/2 REF Volt......................0.67X
CPU GTL 1/3 REF Volt......................0.67X
North Bridge GTL REF Volt ................0.61X
FSB Vref.................................. 2A
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Auto
Clock Setting Fine Delay..................Listed Below
Flex Memory Mode..........................Auto
CAS Latency Time (tCL)....................5
RAS# to CAS# Delay (tRCD).................5
RAS# Precharge (tRP)......................Auto
Precharge Delay (tRAS)....................15
All Precharge to Act......................8
REF to ACT Delay (tRFC)...................60
Performance Level.........................10
Read Delay Phase Adjust...................Listed Below
Write to PRE Delay (tWR)..................14
Rank Write to Read (tWTR).................11
ACT to ACT Delay (tRRD)...................3
Read to Write Delay (tRDWR)...............8
Ranks Write to Write (tWRWR)..............Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................3
ALL PRE to Refresh........................8
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Auto
Channel 1 Phase 1 Pull-In.................Auto
Channel 1 Phase 2 Pull-In.................Auto
Channel 1 Phase 3 Pull-In.................Auto
Channel 1 Phase 4 Pull-In.................Auto
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Page
DLL and RCOMP Settings .................By Menu
Ch1 DRAM Default Skew.....................Model 5
Ch2 DRAM Default Skew.....................Model 5
RCOMP Setting.............................Model 0
Fine Delay Step Degree....................70ps
Ch1 Clock Crossing Setting................Auto
DIMM 1 Clock fine delay...................Current 2476ps
DIMM 2 Clock fine delay...................Current 2476ps
Ch 1 Control0 fine delay..................Current 472ps
Ch 1 Control1 fine delay..................Current 472ps
Ch 1 Control2 fine delay..................Current 410ps
Ch 1 Control3 fine delay..................Current 394ps
Ch 1 Command fine delay...................Current 472ps
Ch2 Clock Crossing Setting................Auto
DIMM 3 Clock fine delay...................Current 2492ps
DIMM 4 Clock fine delay...................Current 2428ps
Ch 2 Control0 fine delay..................Current 442ps
Ch 2 Control1 fine delay..................Current 442ps
Ch 2 Control2 fine delay..................Current 346ps
Ch 2 Control3 fine delay..................Current 332ps
Ch 2 Command fine delay...................Current 442ps
Ch1Ch2 CommonClock Setting................Auto
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
http://www.edgeofstability.com/image...f_lin_64_s.jpg
XP SP3
http://www.edgeofstability.com/image..._occt_xp_s.jpg
http://www.edgeofstability.com/image..._3d06_xp_s.jpg
http://www.edgeofstability.com/image...warhead_xp.jpghttp://www.edgeofstability.com/image...farcry2_xp.jpg
3dx Max w/V-ray
Time to render: 13min 05sec
http://www.edgeofstability.com/image...chmark_680.jpg
TMPGEnc XPress
1GB VOB file ripped from DVD movie
http://www.edgeofstability.com/image...ncode_xp_s.jpg
http://www.edgeofstability.com/image...f_cin_xp_s.jpg
http://www.edgeofstability.com/image...erest_xp_s.jpg
Vista 64 Bit SP1
http://www.edgeofstability.com/image..._occt_64_s.jpg
http://www.edgeofstability.com/image..._3d06_64_s.jpg
http://www.edgeofstability.com/image...3dvan_64_s.jpg
http://www.edgeofstability.com/image...pcvan_64_s.jpg
http://www.edgeofstability.com/image...warhead_64.jpghttp://www.edgeofstability.com/image...farcry2_64.jpg
3dx Max w/V-ray
Time to render: 14min 50sec
TMPGEnc XPress
http://www.edgeofstability.com/image...ncode_64_s.jpg
http://www.edgeofstability.com/image...f_cin_64_s.jpg
http://www.edgeofstability.com/image...erest_64_s.jpg
Where do I get the 10/30 bios?
I downlaoded latest bios from DFI (it's the 10/07 I think) and the issue is still there.
As soon as EIST is enabled, it raises the Vcore to 1,39V when loaded (idle is 1,23-1,24V like it should be). Tried with Vdroop control enabled and disabled.
EIST off and it's 1,23V regardless of C state (running the E0 E8400 at 4Ghz).
C1E always enabled...
DFI's site - Beta section
10/30 BIOS
Thanks.. will try tomorrow. Apart from that the mobo passed every test I could think of with flying colours. I only had to lower GTL refs to 0,63.. the E8400 hated the stock GTL settings (0,67) of the mobo :shrug:
Well, if EIST would work, the whole rig would consume approx. 50W less while in idle. Subsequently, temps would go down, which in turn means lower fan rpm.
If only they would have implemented some sort of fan control (no, CPU fan only is NOT a fan control...). If I had to pick 1 point I don't like about this board, it would have to be the lack of fan control capabilities.
This is when I wish Abit wouldn't leave the market...
Oh i love this little thing, but how stable is the vcore? Is it "Commando VCore", or is it pretty stable with only 4 phase.
With Vdroop control disabled, the Vcore doesn't move 1 bit like on the "big" 8 phase X38/X48 UT/LT boards. Idle = load Vcore, at least with the E8400@4Ghz.
Nice, then its this or the ud3p, need a mono to keep my ddr2 rig alive. Any sugestions?
I am happy to report that EIST works correctly with the latest 10/30 beta bios. 1,15V idle/1,23V load now.
Thanks. I only use E8400's at max mult with this mobo tho.. got 5 DFIs in yesterday, all 5 gone already :D
Best E8400 needed 1,19V to do the 4Ghz, worst 1,29V. All liked the 0,63x GTL ref/1,10V VTT combination for FSB 445.
I really like this mobo, no headaches really.
cant wait for that M-ATX board to come out
anything new on this mobo? BIOS, Quad and so on?
