"try flashing like 100 times per night like i am currently"
I'm not that tenacious during the week. This Thursday, Friday, my weekend, I'll tear it up and find out what my cards can do. I do follow your tip strategy, works well for me.
Does HD4870X handle 1.35V with std cooler?
Do you mean 4870x2? Yes, easy.
I'm using 1.55V and 100% fan speed. It doesn't even get as hot as on stock fan speed and voltage :)
That would likely be hardmodded
But its only adjustable after the hardmod?
with the asus top bios my cardfan runs @ 100% the first 2min and than the speed goes down.
have anyone a other and better bios for me?
i have the std. cooler.
Hard question, without voltmod what is the highest voltage I can set in bios with RBE? Tim? Anyone?
Sorry, but you gotta have RBE working for that, Can't imagine why its not for you.
Stock Sapphire.
http://img380.imageshack.us/img380/8305/93959133ol0.jpg
Asus TOP from T_M.
http://img54.imageshack.us/img54/374/71664858zd6.jpg
From multimeter reading, I'm pretty sure it doesn't make any difference.
thx fornowagain
i have download it now from the nl mirro and now it works.
can you say me settings that i can run with stockcooler without probs
Is 1.55V really available trough bios? No hard mods?
Does anyone know how to get over that 900MHz GPU ?
It seems to be a wall there right ?
Clocked with AMD GPU Clock in Vista64. It works fine but at any clock Speed above 900 Core immediately freeze in 3d Mode.
http://www.abload.de/thumb/900_10001es.jpg
No Solutions yet ?
And can someone really 100% confirm that Vcore Changes with RBE are working ?
to be honest if you can run 900 core in any benchmark you've got a hell of a card not many can run over 860 even at 100% fan speed
ah right never noticed the temps still not many can run 900 in 3d bench with these
The highest volts i could successfully set in BIOS was 1.35V.
At 1.36V my system would not load windows.
900 core on TOP bios can be broken only by uninstalling CCC, then it will work awesome.
