that is the reason :D :
started sleeving the psu cables
first i made the p4 cable and the fan cable
http://tremeloes.kilu.de/meisterkuehler/_MG_8188.jpg
closeup:
http://tremeloes.kilu.de/meisterkuehler/_MG_8189.jpg
there is one problem with the p4 cable. it also has this new plug with 6 pins and this plug doesnīt fir behind the mb tray. so i had to remove it. looks not so pretty but you wont see it later.
http://tremeloes.kilu.de/meisterkuehler/_MG_8190.jpg
built in:
http://tremeloes.kilu.de/meisterkuehler/_MG_8184.jpg
you can see that i doubled the sleeve. i have to be some more accurate when iīm going to sleeve the Atx cable...
