Nice results so far fellas, anyone going to show some gaming benchies?
http://my.ocworkbench.com/2008/gigab...290%20copy.jpg , http://my.ocworkbench.com/2008/gigab...291%20copy.jpg
Have you pressed the ctrl+F1 in the BIOS? :)
Nice going charged!
You said the Phenom first only did 2.8Ghz and was hardly stable. Were you actually able to clock it to say 2.7Ghz and let it be 100% stable (so no idle freezing either?).
My CPU couldnt boot really above 2.8Ghz. Sometimes I was lucky and managed up to 2.9Ghz, but when pressing enter to log on everything froze (no matter what Vcore, usual SB600/Phenom problem).
I actually got even at 2.6Ghz idle freezes, then gave up and let everything run at stock.
For the Asus M3A78-T board, i think I read somewhere the BIOS wasn't 100% yet, if I didnt read it, I most certainly know it anyhow:p:.
I'm going to pop the 9850 out of my box again later and give it another go I think. I'll see what it can do at 1.400V and with ACC set to Auto. I hadn't tried that.
Try uninstalling the AOD 2.1.2 and rebooting.
Then make sure ALL directories have nothing in them for the AMD/AOD stuff.
DIRECTORIES:
MAIN: C:\Program Files\AMD\AOD
C:\Users\USERNAME\AppData\Local\AMD\OverDrive in vista
(Or C:\My Documents\..... in XP.)
After those are clean you can then reload AOD 2.1.2 and hopefully it will work better. (I had that version crash until I did the above. Now it works fine.)
Perhaps I should clarify. I haven't had any AOD related crashes or problems. It is just that ACC (despite being enabled and showing so) wasn't getting me anything.
Oops. Sorry... thought you had issues with that also.
Keep us posted on how it works... if you retry your 9850....
BTW: I think the problem with AOD on my original install before uninstalling and reinstalling was that the AOD service somehow did not get installed. (So anyone having problems... check and make sure you have that service.)
Interesting, bingo. I noticed that there weren't any BIOS updates available on the website, so I'm assuming 0304 is a beta somewhere? I'll fire up the ASUS again and give a look to see what BIOS revision it has currently.
Whaddaya know? My board has 0204. Where can I get the update?
I'd be very interested in this bios too Bingo... I've Googled but can't seem to find it anywhere. :(Quote:
Originally Posted by bingo13
Could you get us a link?
Thanks.... Dave
I am going to do som Cinebench, 3mark06, vantage, an anything else I can, tomorrow night when I get home.
Cinebench 32 Bit realy sucks with the phenom. Bad Scaling etc.
Try 64 bit and try to get NB as fast as possible and you will get an additional extra boost in performance by near as 10 %
http://www.abload.de/img/test7az.jpg
I hate to sound like a conspiracy theorist, but with regards to benchnmarks, I am now at the point where I want to know what compiler a commercial program was compiled with.
I will post some other benchies if any one has any the want to see..... I will run 3.3 benchies tonight if I have time. I will throw in the 64bit ones after I get it loaded.. I might try hitting 3.4ghz..but it might take 1.5v eek
Cinebench is highly Intel optimated thats not new, at least for 64 Bit operating System Cinebench is forced to use SSE2 on every processor. Thats one explanation the Phenom does much more better with 64 Bit in Cinebench except the better 64 bit implemetation on AMD CPUs
For example (Cinebench)
32 to 64 Bit on a Intel system gives you an extra boost about 10 %
32 to 64 Bit on a AMD system gives you an extra boost about 20 %.
Plus Cinebench doesn't use vector SSE at all,but instead scalar SSE which has zero improvement going from K8 to K10(and why would they improve scalar SSE??).The main point in using SSE optimized code is to try to vectorize the apps so that they can use the full potential of SIMD.
Also i wonder what SSE path is used with non intel chips in Cinebench.Penryn gen. uses SSE4.1 optimized path,while Conroe is on SSE3/SSSE3 i believe.
look at Agner's post at aces' here for more on the complier CPUID rigging:
As you can see above,AMD is fighting an uphill battle here,it won't be easy at all.Especially when apps are complied with intel's compiler with above mentioned rigging in mind.Quote:
Originally Posted by Agner
performance rigging?
didnt know, honestly. its a shame a company such as intel would do such a thing :down:
or is it the software companies?
maybe intel has influence on software companies. would not surprize me, tbh.
