Volts are quite low so far - only about 1.3 for 4.5ghz but temps are a bit nuts at high sixties to about 70 - kind of nervous territory for me. this is with water cooling:(.
With all the different temp readings from the different monitors being an issue lately, i wonder if these new chips are being read wrong...........Maybe unclewebb knows.
Dont think this is going to scale well. minimum volts needed under droop to do 3.6
My E8600 coming wednesday
What is the FSB Termination (VTT) voltage for let's say overclock between 4.2 Ghz to 4.5 Ghz????
these cpus look insane, ordered from newegg, could be here thursday if it ships from NJ, free 3 day shipping.
same here i am looking for 4400+, my e8500 does 4.2 24/7
Meh. Having problems with Core Temp and Real Temp getting a reading on my e8600 in my DFI Blood Iron (back-up mobo to my Biostar P45 - don't ask :rolleyes:) however the DFI system monitor is getting a reading. Its way lower than the bios reading, but at least it gives me a reference point and I can see see the jump in temps as I try to put a load on it. To start I wanted to see if at what point my Swiftech 220 Compact Kit would be unable to handle the jump in heat, to get a general idea of where this CPU would land. Set my ram to loose SPD timings and my multi to 10. I guess my cooling is good enough to just touch 5GHZ but not stable for more than a screenshot.
http://img166.imageshack.us/img166/1...5ghzmi5.th.jpg
If I had to take a guess, I'd say this Q820A597 on water is probably good for 4.5ghz on water for a 24/7 rig. I'll be testing more as soon as I find out whats going on with my Biostar Tpower P45 mobo. :confused:
5Ghz 32M stable (watercooled)
http://www.abload.de/img/5ghz-32-26y5.png
max. clock with water
http://valid.x86-secret.com/cache/screenshot/401243.png
http://valid.x86-secret.com/show_oc.php?id=401243
Amazing CPU Chri$ch, what stepping?
you mean the batch? Q822A435
Yeah, that's what i meant, stepping is a legacy from the AMD era. ;)
Can you tell me what your watercooling consists and what was your ambient temp?
I can't wait to get me one of these babies.
Jebus Chri$ch, you know how to kick a guy when he's down. :D Seriously nice CPU you have there.
@ Zeus
EK Supreme and Mora 2 Core + 9 Fans.. Water @ ~28°C
Another Q822A435 - VID = 1.2000 :toast:
First test on Air (HR-01 Plus + 1000rpm - VTT 1.26V - NB 1.48V):
http://img80.imageshack.us/img80/472...0vidairzh7.jpg
Will look for 24/7 4.5GHz+ primestable settings a little later..
Great CPU Rabor, may i ask you where'd you get it from?
And what batch# please?
@ zeus
read his post for the batch ;)
So maybe 4.5ghz a good 24/7 setting? Orthos seems to have "unstuck" the temp readings for both Core Temp and Real Temp. :confused:
http://img373.imageshack.us/img373/2...4500rq4.th.jpg
I would like to hear from some of you regarding temps with this chip. At 450*10 with a vCore of 1.35 I am getting a temp reading from Real Temp in the eighties yet when I touch my water block it is cool to the touch.
I have remounted my block several times with no changes. I am at the point of thinking that the sensors in this chip are really screwy .
At 440*10 and a stable OCCT vCore of 1.26875 I get a max real temp of 63c which is still way too high, imo, for that vCore.
I would appreciate hearing some other results.
:eek: holy crap These E8600 are crazy !! i order one today :D looking for 4500-4600mhz stable
cpuz validation
anyone having issues with 1.46v and e8600's and saving and submiting cpuz files to the orb thingy?
