We need a list off DDR3 modules that has a Micron D9JNM chip!!!
And to see which Manufacturer gets the best OC.
So please please share whit use.
I really need some D9JNM mem's to see mine system running smoooth :D:rolleyes:
signing up for the info if its ever revealed anyway
well you can start adding to r00n's list at http://ramlist.i4memory.com/ via http://i4memory.com/f94/ddr3-ic-list-submissions-8426/ :D
Cmon man we know that YOU cant GUARANTEE the same results. Please just let tell us what kit it is. Were not going to hold you responsible if we dont get the same great overclock. We all dying to know what manufacturer/kit this is. Prettty Pretttttty Please tell us? :yepp:
Which die rev?
A or B?
Tony does your posting mean this is OCZ memory? :D
Any links to stores with these Kingmax 1600Mhz kits in stock?? I cant find one anywhere on the web!
Update:
More tuned results(point on lower vdimm):
NB~1,607v
RAM~1,812-1,819v
2000 8-8-8-25 2T 32M done
http://img362.imageshack.us/img362/1...819vnb1am1.jpg
NB~1,607v
RAM~2,044-2,05v
2220 8-8-8-28 2T 32M done
http://img516.imageshack.us/img516/4...4205vnbgl4.jpg
trfc = 110 ... how much more vdimm does it take for you to run with trfc = ~72-78 ?
Less..:rofl:
NB~1,515-1,521v
NB temp~55C load.
RAM~1,806-1,812v
TRFC~72
http://img231.imageshack.us/img231/8...812vnb1qs0.jpg
2000 8-8-8-25 2T..
NB~1,501-1,508v
NB temp~55C load.
RAM~1,806-1,812v
TRFC~60 :D
http://img216.imageshack.us/img216/9...812vtrfbd1.jpg
for 1000+ mhz ram on R.E. what king of settings u use ? dram skew ? cpu skew, nb skew ? dram ref voltage ?
bro, if you publish dram skews than let the public know which skews you used. clk or cmd? :up:
right, but first of all try with only cmd skews
ok thanks, that is what i need to push my memory :)
You got nice chips,keep pushing:)
booyaaa! take that samsung! :D
only 2v and even with 1t! very nice mem! :toast:
hehe^^, Good Luck:up:
I must take a break, because my RE is died:(, I waiting for new one..But I test them in Gigabyte P45T-Extreme until RE is back:D;)
Thanks my friend!:D;)
As I wrote P45T-Extreme arrived..some quick test with KINGMAX..:D
CPU-Z valid: 2340Mhz 8-8-8-28 2T DC
CPU-Z valid: 2402MHZ 10-10-10-34 2T SC
