Hey got a question for you guys with MM. Do you know what size #6 screw is needed to fit a fan grill, yate loon, filter, neo pad, and then screw into the thermochill radiator. The thermochill screws from petras are only long enough for the fan, neo pad, and the radiator. Im guessing you guys cut your own to fit perfectly?
edit - #6 Sheet Metal screws 1 1/2" did the trick. To bad they didnt come in black. Nothing some paint cant fix.
