might not need it if it runs very well and the price is right.
id like more ram though. maybe another edition would follow at a higher price:up:
thats the chip your looking at:
http://www.plxtech.com/products/expresslane/pex8648.asp
Hornet331
But certainly, it does not look like a PEX 8648?
damn i see a damn hot card
hope the cooler is better than the other 40**
So this proprietary new interprocessor communication they talked about.. Either it was a load of hype BS about a PCI-E 2.0 PLX switch, or they're saving it for R800, or.. There's more to that chip?
I don't think that most of the communication will go through the PLX chip but rather through a direct connection between the 2 chips. That connection will probably (I'm pretty sure though) not provide enough bandwidth to make some kind of memory pool sharing possible but it will probably provide increased scaling.
@Hornet331: I think it will beat 2 4870 in CFX in most situations, it will only lose on some rare occasions.
Dave Baumann (ATI employee) has hinted over at Beyond3d that it may not be that PLX chip that you linked to Hornet....
Linky:
http://forum.beyond3d.com/showthread.php?t=48691&page=8
further down on that page.
BTW guys, I'm just speculating...I hope you guys have no objections with that :p:.
As for the chip, it probably just has a metal heatspreader over it.
Not to mention all PLX chips seem to look alike. :D
Do you have any info about whether this card is going to have a possible mechanism to reduce or eliminate microstuttering or multi-GPU driver issues? If not I don't think it will be beating the GTX280 in games with poor or nonexistent multi-GPU support since a single 4870 can almost never meet/beat a GTX280. OTOH, unless something goes horribly wrong the R700 certainly should utterly destroy the GTX280 in frame rates in games with multi-GPU support. In theory 2 4870s should give about the same performance as GTX260 SLI. I am really hoping that AMD/ATI is going to do something about the microstuttering issue though. Having parts of the game perform at the same level as a single card quite significantly reduces the value of multi-GPU for me.Quote:
Originally Posted by w0mbat
damn, i do not see how a 6-pin plus 8-pin would be nuff 4 this...
tis like powering 2 8800gtx chips on 1 card..
i thought it would require 2 8-pin power connectors!
1300W PSU minimum for xfire???
there's only one problem with your theory. A single 4870 beats the gtx 260. Considering xfire is supposed to scale better than sli and the possible there may be an internal ht bridge or something like that for a fast low-latency inter-connect, then it's safe to say the 4870x2 will be closing in on gtx 280 sli
2 x 8pins? Even the 1.1 PCIe + 6pin + 8pin is 300W, if it was over 300W imagine the cooler needed.
The HD4870 only beats the GTX260 if you choose your reviews and the games in the reviews and your resolution with great care. OTOH, I could go cherry pick reviews that clearly shows the HD4870 losing badly to the GTX260 in multiple benchmarks. The fact is that the GTX260 and the HD4870 are trading blows. Although in reading reviews from sites that I know and trust the HD4870 seems to be losing by greater margins when it loses than the GTX260 in the games where it loses. Also, it looks to me like the GTX260 has more OC headroom. With an apples to apples water cooled OC comparison I believe the GTX260 OC is going to win against the HD4870 OC in nearly every benchmarks except those few where the HD4870 does unusually well.Quote:
Originally Posted by aliG
Also what is with this CF is "supposed to" scale better than SLI? In the benchmarks I have seen if anything it seems to scale worse and CF is often stated to have worse driver support in games than Nvidia. The game industry has been very Nvidia biased since the 8800GTX took the crown. Hell there was a lot of speculation that AMD/ATI may not even be around anymore due to their huge financial problems which are not even over yet.
The internal HT type bridge idea is extremely speculative. In fact most of the current rumors seem to be that R700 is going to be some sort of crossfire on a card with a faster bridge chip. Remember all the crazy rumors before R600 was released? Some of the rumors were even talking about improved GPU communication IIRC. I suggest we adopt more of a wait and see attitude rather than these type of ultra-optimistic assumptions.
When is premier of this beast ? :)
Happy to see a black pcb on ATI.
