Cool! (literally) Then it is confirmed that it is compatible hith the HD48X0 line? :)
Yep, any cooler that fits on the 3870 should fit fine on the 4870. They share the same mounting holes
Hardwarecanucks has a section in their review where they explain aftermarket cooling solutions, check it out. HR-03gt does very well, the Accelero S1 is probably a few degrees higher in comparison, though half the price.
my S1 does a GREAT job... i have two 120mm at 100cfm each..
the card is hardmoded of coarse..
4850 with s1:yepp:
http://www.buydurango.com/josh_files...SCF6273750.jpg
I hope so Richard. Every match since the beginning of the Euro has been a complete party, I will be in the core of it tonight and in the final too if we beat the Russians. Even if we lose the party will be long, very long (as always in Spain :p:). And considering the 4-1 in the first round I think we will play against Germany :D
Just recieved 2 pieces of HIS 4850. Havenīt changed to Artic MX2 yet. But idle temps in CCC is around 70-80 degrees.
Waiting for some new tubing, then iīm going to watercool both cards with Maze5 blocks. Hope it will do great on temps :)
dont worry about temps these things are cold as hell...... if the fan on your stock sink was even at 60 percent you would see 50c idles instead of the 70c.. so water you should be well under 30c.... :yepp::up:
edit: finally we can make our submissions public now finally on the ORB.. instead of just 3dmark01..
i didn't have time to read through the whole thread, but when you say that the "700 mhz wall on hd4850 is smashed", you mean that the limit on ccc can go above 700mhz right?
RBE v1.11 just released!
Changelog:
v1.11
- Fixed values written if look up table is used.
- Improved method of clock rates detection (old method was not working properly with some weired BIOSes).
- Added some FireGL device IDs.
- Added some stuff to the in-program-FAQ.
- Undated link to WinFlash.
- Fixed little bug occuring writing some BIOS infos.
- Fixed some confusion regarding 3650 cards.
- Added support for some exotic mobile card's BIOSes (experimental).
- Added support for HD 4850/4870 (experimental).
- Added fan control for most 3870 X2.
Excellent. very well done and thank you!!!!
RBE is working great!
So far I have achieved 820mhz/1100 on the stock cooler. I used a mixture of bios and pencil mod to get 1.17v idle and 1.33 load :)
Once you use RBE to change the fan profile it is actually quite a sufficient cooler.
http://gpuz.techpowerup.com/08/06/26/fes.png
And this is how I changed the fan profile in RBE:
http://img125.imageshack.us/img125/830/59962621kn2.jpg
BAGZZlash is certainly becoming a hero to us all, awesome work buddy, tell W1zzard we appreciate you guys's work so much:up:
I am very impressed so far with the progress made this is going to be a great card for ATI and by doing that it forces the competition to push to a higher level and a lower price..
Thanks for RBE 1.11
Fan control works PERFECT!!
Removed... Damn i feel dumb ;)
Excellent stuff there!
I still get troubles with 2d mod (frequency doesn't change, neither 160/500 nor 500/750). How can I make a smooth fan regulation? I think I'll try the second type of regulation (table).
Thank you very much
i set 1.56V in 3D isn`t too much???
WC installed
725/1125
Avg=26.2
920/1125
Avg=31.0
anizo-16x
http://www.imagehosting.com/out.php/i1811278_920.jpg
http://www.techpowerup.com/gpuz/nqpf/
Comapny of H DX10 anizo=16x
700Mhz
avg=37.5
920Mhz
avg=50.590
before :
http://img529.imageshack.us/img529/8157/originalvt7.jpg
after (only changed Fan speed to 55% - clocks & voltages remain stock)
http://img141.imageshack.us/img141/8672/55tg5.jpg
nice clock chri5g:D is that chilled or regular water?
sub'ed
;p
:up:in rbe 1.11 whats the core speed we have to set to actually get the core speed to change, or is this still a work in progress...
if so i'll continue my trial and error...
heres a pic of my progress so far....:up:
