There is nothing to share, i had them @ auto ;)
for 500FSB 1:2 you need to set all the performance settings (Static read control, mem OC charge etc) @ auto,
otherwise it wont boot (or i get a bluescreen)
i will flash your SPD in it today and test it again, but i dont prefer this profile oc stuffs, like XMP, i like more to set the timings and ect manual.
yes BUT, on most mobos like the Rampage, dont need to play with them to get high clocks on fsb/ram, but the 3 phase P45 mobos like the P5Q3, are really sensitive for this settings, you need to play with the vtt/gtl rate for fsb/ram stability much earlyer than in other chipsets ever needed as my experience... (Maximus 2 Formula was not stable at only 500fsb without good GTL settings, and its only DDR2 mobo)
good luck with the P5E3 Deluxe m8 :)
nice result with 4GB kit, try to lower the timings to 7-6-6 or 7-6-5, 7-7-7 is for JNL :D
heh, tryd Chri$ch's settings, but still the same results with the CSX on my P5Q3, 1800 8-7-6 2.0v and still a ton of errors :rolleyes: (this vdimm was enough for memtest stability at even cas7 in X48) weird
Wouldn't boot Vista already tried it ;)
This board and these extremely good ram sticks are one hell of a combination !
If been through 5 different boards with 2x 4gb kits the last 5 weeks and this is by far the best board and result i got...... most boards realy realy hate 4GB kits especially if you through a high clocked quad in the mix (chipset ?!?!).
The Blackops is performing like you expect and finally stability .... :clap:
i dont know why, but sometimes i have the problem that i can only use a res. of 800x600 if i boot 500FSB 1:2 :(
but its Dual 32M stable
http://www.abload.de/img/dual-32ms1n.png
max. 1M
http://www.abload.de/img/520fsb6tr.png
Well got a bit further.
These sticks love voltage this is at 2.0V
http://xs229.xs.to/xs229/08290/blkps...705.jpg.xs.jpg
Don't mind the pi time and score's.
I'm rebuilding my raid5 array wich take's 20 hours ......
Smokey
Maybe you can try this kit with a Quad-Core 45nm? I really want to know if a quad would make a huge impact...
Oh sorry, didnt notice that! :p: I thought you were one of the guys with E8400, E8500.
So thats the max you can get it up to? ~880Mhz? What vdimm?
Cant you improve your reading on X48 boards like 790is? With P1 & P2 disabled I get 9200 but when enabled I get 11200. (Using F3-12800CL7D-2GBHZ @ Stock)
I have tested several boards (dfi t3rs and a few more) but non could get to these speeds.
The boards are having a real hard time with 4Gb with a high clocked quad.
Believe me if i tell you i tested these boards in the last 5 weeks and none could even come close to what the blackops is producing :cool:
This was a 1.66V @ NB and 2.0V @ Vdimm.
Well 4Gbs with OC Quad means limited overclock for sure thats why I would like to see more testing from people but using quads instead of duals to see how high can they get the RAM.
Thats a lot of NB voltage for that speed, I guess 1600-1700Mhz for the RAM is the spot if you want to have your Quad overclocked.
Maybe the reason why I was suffering overclocking my D9JNL while my Quad was already in 450Mhz FSB.:shrug:
Well got a bit further with the memory can boot right up at 1800 cas 8 (quad @ 450) ..... this ram is realy realy nice :D
SmokeyTheBandit, maybe you can try this SPD i attached with BlackOps and quadcore with XMP enabled? This have 1866Mhz XMP profile, not sure your quad can handle 466FSB stable, but nonetleless this is final SPD for 4GB Diablo kit.
Wow that would be the best and highest speed. OC Quad+4Gbs @ 1866Mhz = Killer
Thanks for the new spd Kasparz :)
Tried it but for now couldn't achieve any higher speeds.
From the testing i done i will keep it at 1760 cl 7 wich gives me a nice 10700 mb/s in everest.
The chipset is having a mayor hard time with anything higher than this for now this will be my 24/7 speed but will be testing with future blackops biosses when they arrive.
They are tweaking the newer biosses to have more/better support for 4gb kits ... more to come :)
Smokey, dont you have any 790i chipset that you can try?
I wish you had one so you could show us some bandwidth scores with P1 & P2 Enabled.
which samsungs are you going to test? I'm very curious how they put up to the d9's.
HC9 Samsungs. These are most likely going for sale as 1600MHz 7-7-8 2GB/4GB CEC kits. D9GTR is a lot better than Samsungs, thats for sure. But Samsungs are a lot better than Qimonda. So if you want cheap but fast DDR3 for your P35/P45, get Samsungs. For X38/X48 and nF790i D9GTR is better.
