Me too, and with 2G kit...
(also posted on http://www.ocztechnologyforum.com/fo...d.php?p=278514)
Hello,
I've got an Asus P5Q3 with an OCZ3P16002GK kit and Q9450 processor, and could only install a system and boot under Splashtop/Linux/Windows by setting DDR3-800 in the BIOS. All other settings I tried with DDR3-1333 (voltage, timings, skew) were unstable. I tried all available BIOSes, even 801 one.
Today I decided to do some tests. Now I've got Prime95 running stable for half an hour (self-test 1024K passed) with the following BIOS settings in System Performance Settings :
DRAM Frequency : DDR3-1333MHz
DRAM Static Read Control : Disabled
DRAM Dynamic Write Control : Disabled
DRAM Read Training : Disabled
DRAM Write Training : Disabled
MEM. OC Charger : Enabled
Ai Clock Twister : Lighter
DRAM Voltage : 1.80
NB Voltage : 1.20
All other settings : Auto
The OCZ kit is on orange slots, the others aren't populated.
Some settings may be useless, but now it's stable I will try setting back each parameter one by one to Auto and lowering DRAM Voltage later, and test stability.
At the time of this writing, Self-test 8K passed.
Hope this helps...
Another thing : SPD says this RAM is PC3-10700... shouldn't it be PC3-12800 ? Btw, when I bought this, the vendor said "DDR3-1600".
Thanks,
Olivier
