If you want you can order one from Portugal:D
ASUS P5E64 WS Evolution build 0501
This one improves much nVidia 9800GX2 VGA performance as well as some others GPUs. (3D01 especially :D)
thanks J :)
Available on newegg.
http://www.newegg.com/Product/Produc...82E16813131300
:D Thanks a lot Kenneth - You inspired me to buy this insane board:
http://img366.imageshack.us/img366/5562/8x575ub7.th.jpg
:up::up::up:
Don't know if those are posted already, but here it goes:
Some voltage measurement points for the P5E64 WS Evolution:
http://i37.tinypic.com/5wf9xz.jpg
p.s. My board overvolts the RAM quite a lot ( 1.60V @ BIOS results in 1.71 or 1.73 [ gotta check my notes ] in reality )
Updated pic with the following voltages measurement points:
CPU Voltage ( Vcore )
RAM Voltage ( Vddr )
NorthBridge Voltage ( Vnb )
SouthBridge SATA/PCI-E 1.5V Voltage ( Vsb_pcie )
FSB Termination Voltage ( Vfsb ) [ aka VTT Voltage ]
DDR3 RAM Termination Voltage ( DDRvtt ) [ Vddr_vtt ]
CPU PLL Voltage ( Vpll )
http://www.benchzone.com/datas/thumb...fsb_ddrvtt.jpg
I still have a hard time getting stable around FSB 445-450 with my setup.
It turns out that my systems crashes (show werid graphics/colors) within minutes in games (COD4, Crysis, Oblivion) when running 445x9 (RAM at 1780) even though it is Prime blend stable and Memtest stable for around 18 h. However running 421x9.5 (also 4 GHz) is Prime blend stabe for 24 h and runs games perfect. I wonder whether it is my CPU or the motherboard/BIOS that is holding me back? I don't think it is my memory since they run error free Memtest and It does not help to loosen timings or use 2N. I have been tweaking for months but can't get it stable at FSB 445+
Stable setting (24 h+ Prime Blend):
CPU Features
Ai Overclock Tuner Manual
CPU Ratio Setting: 9.5
FSB Strap to North Bridge: 333
FSB Frequency: 421
PCIE Frequency: 100
DRAM Frequency DDR:1685MHz
DRAM Command Rate: 1N
DRAM Timings
DRAM Timing Control: Manual
CAS# Latency: 8 DRAM Clocks
RAS# to CAS# Delay: 8 DRAM Clocks
RAS# PRE Time: 8 DRAM Clocks
RAS# ACT Time: 24 DRAM Clocks
RAS# to RAS# Delay: Auto
REF Cycle Time: 72
WRITE Recovery Time: Auto
READ to PRE Time: Auto
READ to WRITE Delay(S/D): Auto
WRITE to READ Delay(S): Auto
WRITE to READ Delay(D): Auto
READ to READ Delay(S): Auto
READ to READ Delay(D): Auto
WRITE to WRITE Delay(S): Auto
WRITE to WRITE Delay(D): Auto
Write to PRE Delay: Auto
PRE to PRE Delay: Auto
ALL PRE to ACT Delay: Auto
ALL PRE to REF Delay: Auto
DRAM Dynamic Write Control: Disabled
DRAM skew: Auto
Ai Clock Twister: Auto
Ai Transaction Booster: Auto
Voltage Settings
CPU Voltage: 1.5625
CPU GTL Voltage Reference: 0.67x
CPU PLL Voltage: 1.52
FSB Termination Voltage: 1.36
DRAM Voltage: 1.82
NB Voltage: 1.53
NB GTL Voltage Reference: 0.67
SB Voltage: 1.05
Clock Over-Charging Voltage: Auto
Load-Line Calibration: Normal
CPU Spread Spectrum: Disabled
CPU skew: Auto
NB skew: Delay 100 ps
excellent review, awesome board...it has all the ports
Does anybody have a bios for this board that supports E8600 cpu ?
Currently running 0501 but does not support this cpu correctly..
Cheers,
Rich.
Yeah, i've tried em all :( Just flashed back to 0401 just to check, but still no go
I dont no if 0504 support e8600, but here it is http://www.benchzone.com/Downloads/B...5E64WS0504.rar
