GX2 will work on any chipset.
"On Gigabyte X48, the R680 had no problem running through all tests. But the 9800 GX2 could only pass 3DMark06 on the very same board. Running any other games would results in errors, or worse, BSoD. Since we know from the previous test that SLI needs to be enabled for maximum performance, yet Intel chipset based boards do not support SLI, we might be looking at a compatibility issue here.
It was then the GeForce 9800GX2 moved to the Striker II Formula platform, where it managed to perform all tests. On the other hand, the 3870 X2 maintained its stability on both platforms. We have to give credit to AMD on its compatibility advantage. In conclusion, we would advice those considering the 9800 GX2 to get a Nvidia chip based motherboard."
http://lly316.blogspot.com/2008/03/g...0-x2_5855.html
:devil:Quote:
The guys who brought us the first GeForce 9800GX2 has followed up with a review of the GeForce 9800GTX. And guess what? It's slightly faster than a slightly lower clocked GeForce 8800GTS. Unfortunately, the review only holds NVIDIA cards; GeForce 9800GTX vs. 8800 Ultra, 8800GTX and 8800GTS. Without any Radeon card, it gets kind of flat, but still shows with the utmost clarity that, at stock frequencies, GeForce 9800GTX is not a necessary upgrade for anyone who already owns a GeForce 8 series card.
http://www.nordichardware.com/news,7513.html
gx2 is sposed to 'debut' at ~600usd:eek: vs 3870x2's ~400+usd
http://www.newegg.com/Product/Produc...ond-_-14103052
http://www.hothardware.com/articleim...em1093/coh.png
http://www.hothardware.com/articleim...tem1093/et.png
single 9800gtx oc should close the gap on 3870x2 stock
http://forums.anandtech.com/messagev...readid=2147532 - some 3870x2 reviews with fps...
if gx2 works (drivers?????????????????) it could be a monsta performer!
http://images.tomshardware.com/2008/...2/image003.png
30" res is where you 'need' that 3870x2 or gx2...... i reckon.
g80 or g92 cards will come very close to 3870x2 , imo, at yr normal res of 1280x1024 16x12 and 19x12....or so the review charts indicate to me....8800gt ftw for shear value power!!:hehe:
3870x2 is king:worship: ...for now.
9800GTX FULL Review OUT!!
http://aycu21.webshots.com/image/471...2276493_rs.jpg
http://aycu22.webshots.com/image/485...4819061_rs.jpg
http://aycu13.webshots.com/image/466...1211579_rs.jpg
http://aycu40.webshots.com/image/493...1134236_rs.jpg
http://aycu17.webshots.com/image/455...9522234_rs.jpg
http://aycu31.webshots.com/image/449...8930759_rs.jpg
http://aycu03.webshots.com/image/468...0896413_rs.jpg
http://aycu10.webshots.com/image/473...7007632_rs.jpg
http://aycu28.webshots.com/image/464...1383314_rs.jpg
http://forums.vr-zone.com/showthread.php?t=249185
http://www.pconline.com.cn/diy/graph...3/1243353.html
:up:
Seriously CPU limited there at only 3ghz... and no high detail settings... but already nice to see thx Mascaras
bah - cant people use oblivion to test :(
these thing are going to clock like CRAZY!!!!!
This is the highest binned gddr3 on the market, going into these things, people have the mem up to 2400mhz!!!!!!!!!!!!!!!
I can't wait to get one.
thank you nvidia for releasing an gtx that isn't rediculously overpriced like the 8800gtx.
Well its about damn time they changed that god awful stock cooler that pumped HOT Air into the Case which killed the whole concept of Rear Exhausting the Hot air:rolleyes:
