GIGABYTE GA X48T DQ6 Clock Settings
MB Intelligent Tweaker (MIT)
Robust Graphics Booster...........: Auto
CPU Clock Ratio...................: 9
CPU Frequency.....................: 3,600
CPU Host Clock Control............: Enable
CPU Host Frequency(Mhz)...........: 400
PCI Express Frequency (Mhz).......: 105
C.I.A.2...........................: Disabled
Performance Enhance...............: Standard
System Memory Multiplier (SPD)....: 4.00D
Memory Frequency(Mhz).............: 1,600
DRAM Timing Selectable ...........: Manual
Standard Timing Control
CAS Latency Time (tCL)............: 8
DRAM RAS# to CAS# (tRCD).........: 7
DRAM RAS# Precharge (tRP).........: 6
Precharge Delay (tRAS)............: 21
Advanced Timing Control
ACT to ACT Delay(tRRD)............: 7
Rank Write to READ Delay (tWTR)...: 7
Write To Precharge Delay (tWR)....: 7
Refresh to ACT Delay (tRFC).......: 72
Read To Precharge Delay (tRTP)....: 7
Static tREAD Value (tRD)..........: 7
Static tREAD Phase Adj............: Auto
Command Rate (CMD)................: 2T
Clock Driving and Skew Control
CPU/PCIEX Clock Driving Control...: 900
CPU Clock Skew Control............: Normal
(G)MCH Clock Skew Control.........: Normal
System Voltage Control () = Base Voltages
DDR3 OverVoltage Control...(1.50v): +0.30
PCI-E OverVoltage Control.,(1.50v): Normal
FSB OverVoltage Control....(1.10v): 0.30
(G)MCH OverVoltage Control,(1.45v): 0.3
CPU GTLREF1 Voltage*.......(67%)..: Auto
CPU GTLREF2 Voltage*.......(61%)..: Normal
Loadline Calibration..............: Enabled
CPU Voltage Control...............: 1.5500v
Normal CPU Vcore..................:
Note: * Hidden Features Press [CTRL] + [F1] from main Menu to Access
Advanced Bios Features
CPU Multi-Threading...............: Enabled
Limit CPUID Max to 3..............: Disabled
No-Execute Memory Protect.........: Disabled
CPU Enhanced Halt(CIE)............: Disabled
CPU Thermal Monitor 2.............: Disabled
CPU EIST Function.................: Disabled
Virtuaalization Technology Disabled
to show us your current settings m8
