Originally Posted by
Jupiler
A quick note from me regarding the XSPC tops (both normal and with reservoir) and the barbs used.
I ordered 2 normal XSPC tops (8.50€/each) and the res top and got them yesterday.
As I have 6x 1/2" EK and 6x 1/2" DD barbs laying around, I wanted to check if they fitted nicely in the G 1/4" threads. Normally they should (at least, that's what I expected).
Unfortunately, I ran into problems when I tried the barbs.
Dangerden barbs :
I bought about 12 pieces from PTS last year and 6 of them are in use in my several WC rigs.
When I tried to twist the first barb into the thread, it blocked after only 1 full turn. I found this weird, took the barb back out and tried again. Same thing, wouldn't turn in.
Tried it in the other thread of the top but same problem, could do 2 turns and then it blocked.
Same thing with 4 other barbs and the 2 tops and res top, they simply wouldn't fit.
Only 1 barb would turn in into the threads of the 3 tops.
One other barb would fit into 1 top but not in the 2 others.
Weird, if you ask me.
EK barbs :
No problems with all 6 of them on the 3 tops, they fitted nicely.
I then decided to check if the DD barbs would fit into the Alphacool and PTS tops.
No problems whatsoever with all threads of the tops.
I don't know what to think of this.
Were the G1/4" threads on the tops not properly tapped in by XSPC, so they might give problems with certain barbs?
Or is there something wrong with the G1/4" thread from the DD fittings?
I don't see why there should be something wrong with the DD barbs, as they fit without problems in the Alphacool and PTS tops.
Think I'll be using the EK fittings with the tops.
