+1 :yepp:
I'm deathly allergic to tiny holes and slots in my water blocks. :rofl:
Definitely interested in this, since I spent $10 on extra Quad plates for my v2 (accidentally added 2 to the cart - such a small amount, didn't notice).
If there's any improvement, I'll pull the Quad plate next time I have the case out.
-bZj
Thanks Andy.
What is the GTZ you mentioned early on?
JM
Ah thanks. I dig the test bed setup. You obviously dont have kids/cats that wonder the house, waiting to test your patients :p
JM
It seems that the EK Supreme beats the D-Tek in single CPU loop. That's ok for me.
What about adding several WB in the loop? Is this still the same "supremacy"?
Mr-Rob,
OK no sacarsm necessary... Both are great water blocks.. everybody happy now ?
Thanks Andy for your time and efforts.
Could you post the log results for the one pump only loop?
I think this is more the average XS member build.
Can't wait for the no-nozzle test and the GTZ.
Sarcasm? :confused:
I have a EK Supreme on a Maximus Formula (+Q6600), in a loop with 6 WB (GPU/NB/...). I'm very happy with it.
The question is that I have a NexXxos XP˛ HighFLow on a Maximus II Formula (+e8400), in a loop with 2 WB. I just want to change my WB because the "fixation" of the XP˛ is quite "boring": I often switch CPUs and I need something quicker to unmount.
->So, in order to test something else, I just wanted to know if there is a bigger differences with more WB in a loop.
If it that close in term of perf, EK is cheaper :D
I apologize. Well, you have chosen the best waterbock in the market. Its obvious it works well in your multi-block loop, as long as there is adequate head pressure.
In any event, even if the FuZion V2 were to perform any better under your circumstances, the improvement would be minimal. If you are concerned about the EK being "cheaper" then it would certainly not be cost unproductive to have to rush out and buy a FuZion V2 as well.
I would stick to what you have, and if there is a performance issue, then there's the excuse to buy a second pump.
Hope that was useful.
:up: Price is not the real problem :rolleyes:. And I don't really need to change in fact because i've got nice temp'.
It is first for a easier way to unmount the block . And I admit: testing something else than NexXxos and EK :p:.
Thx for your answer... I'll take a look at Apogee GTX, Cuplex XT DI too
:buddies:
Look at the forthcoming Apogee GTZ.
Never mind the Apogee GTX. I have one myself. It isn't worth your trouble because its not the equal of the EK.
Awesome testing, thanks for taking the time to not only test with one, but two pumps. I was really curious if that was going to flop things around or not, but you've just shown it doesn't.
Thanks!!:clap::clap:
Martin
v2... no worries about clogging FTW!!! :up:
Andy, thanks for taking the time to test and post your findings. If I were a betting man I would have lost big time. :D
Your comments earlier in this thread with respect to the Cuplex DI caught my attention. Was this Cuplex DI tested in the same loop as the V2 and Supreme?
Seriously IanY hit it on the head. Neither of these blocks should leave you dying for the other one unless you happen to prefer an acrylic block (EK). People can and DO lose a degree or two just in a so-so mounting, or an elbow in a tough place. Relax. Both blocks will serve their purpose well.
I'm also looking at doing some serious (as in somewhat scientific/accurate results) watercooling testing. Would you say that all the temp sensors (air in/air out) are necessary? Because if not I will probably go with calibrated sensors on an Aquaero (can only hold 6 sensors).
Also, how are the sensors connected to the Crystalfontz thing and how time consuming is it to learn the software and set it all up?
And thanks for doing the testing mcoffey! One thing though, it looks like you did just one mount there per block, can you confirm (through previous experience/testing) that those were actually "as good as it gets" mounts? Because at that kinda temp difference the block with the "better" mount usually wins.
Edit: Nevermind Andy, missed this post:
Still that sound issue is a major problem.
Hope you can soon test it at stock, no nozzle, to see if it's still there. That noise thing is really irritating. Changing the flow/pump speed, you could see if it's only appearing on too high flows
Thanks for creating the test. Ek acrylic block is probably the best looking block I have seen.
