Coooper, what in da world is wrong with my post, except for the fact that it wasn't pro-AMD?
HP selling stuff at Wal-mart deserves a ridicule!
Just keep telling yourself that.
AMD was eating away Intel's market share for years in a row, and you think the agressive pricing, marketing and development plan of Intel is just a coincidence? The tick-tock model didnt just fall out of the sky around 2005.
We can already see them taking some pressure off as AMD keeps failing.
Intel will cut down to what they think is an optimum between cost and production, as soon as they feel safe. Even someone with a moderate economical education can udnerstand that. And looking at the past, it's safe to say that what they have done with Core 2 and Quad is far above that optimum - especially in the light of the agressive pricing.
Thank you for those links, this is the first time i see the bug in action.
The guy who answerd is working for AMD according to his sig, so it seems to be no BS this time.
I could not make the bug occure with xen and differen guest osses all running prime95 or other benchmarks.
It would be interesting what software he ran.
It is not as easy as such. The guess is its due to hot spots. Thats also one reason it could be safe at under 2.4Ghz. So Its abit like OC and chips. Random picks. Maybe only 5% of all chips have this bug at stock speed. And with an increased chance with higher frequency.
if it was a fixed bug so to say. I am pretty sure AMD would have caught it in their QA process.
We have a few people here with 0 bugs, and we have an example of a person in WCG forum where it crashes.
There is a detailed description of the TLB-thing at LostCircuit here.
I dont want to say the bug does not exist, but i experienced it is pretty hard to trigger it.
Thx, gona try to trigger the bug with WCG. Do you remeber when the crash was reported in the WCG forum.
According to LostCircuit the bug can only occure with hardware enabled virtualisation. What did the person at WCG use?
He just ran WCG and it crashed a few times.
Also i think you misunderstood my post. Its not hard to trigger as such. It just depends on your luck of CPU. If there is a hot thermal spot or not and if so, at what frequencies. I do not believe it s a virtualization only bug. Its a pretty lame excuse. Also you would just have the BIOS setting where you disable or enable virtualization to enable or disable the fix aswell. I call it a smoke screen ;)
I don't think WCG can trigger this bug. I've been running Phenom 9600 at stock on WCG for 4 days non stop - not a single crash. I beleive there are few more ppl that run WCG or any other F@H app on Phenom even on higher clock speeds. this is just not that kind of load. Though if you running something elsevery CPU intensive...don't know. This guy at x86-64...there is no explanation of what exactly he was doing to get this error
What type of calculations set off the bug though? Surely something cache and CPU intensive...
NP I wrote a mail to x86-64 with a link to the description, waiting for feedback now. The reviewer seems to be an amd-fan so i do not trust that guy.
The hotspot thing is speculation atm. No phenom user in the AMD section could find a relation between stability and temps or between stability and the tlb-fix.
Maybe you are right and not all cpu's are affected. But that whould be something AMD-marketing whould have mentioned.
Here is an success report for the linux tlb-patch.
Best answer I can give you is it not crashing under full load at all. The stock one is running Boinc 24/7. The OC'ed one, the only time it's not running Boinc is when I'm gaming or benchin'
True. Especially if your running virtualization on that Server
The thread title is about Phenoms not Barcelonas.
I don't think you'll see too many using a Phenom for virtualized mission critical servers.
Is TLB bug on Phenom going to crash Average Joes(sinlge OS Windows machine) multithreaded game...No
The TLB bug doesn't prevent you from overclocking but overclocking should increase your chances of tripping the bug
Can anybody show me that somebody actually tripped the TLB bug on Phenom(not Bacelona) running a single OS. Please, because I want to try too.
The crashing on WCG probably has more to do with ram compatibility.
what is the argument for, or technical details behind, an overclocked phenom being more likely to trip the bug? or is that just people's experience?
The whole launch was PR suicide.
They know in what circumstnaces the bug occures, there is a good decription from amd here.
I guess it should be possible to write a test case for the errata.
Such a test whould be no option for tier1's but for desktop users it whould be a nice stability test.
So if you are right that whould be actualy good news for phenom/b2 users. :rolleyes:
The NB and the L3 cache runs at ref HT (FSB) * NB multi (max 9 for locked phenoms). The multi can be modified with wprcedit.
The NB speed is independant from the memory speed (ref HT * mem multi/mem divider).
NB speed becomes an issue above ~2100MHz, ref HT at ~260MHz.
Paul Demone's view on the bug :
This is the reason why AMD locked the NB speed , they tried to get rid of at least one variable.No wonder that the bug is hard to fix ; it's non-deterministic.Quote:
It probably isn't a straight forward logic bug in synchronous
logic. The four cores and the L3/IMC can all run at different
frequencies and thus there is asynchronous interfaces between
them. AMD might have tried something a bit more aggressive
than straight out double sampling in both directions to reduce
latency crossing clock boundaries. And when two CPUs running
at different frequency and/or phase hit their L3 interfaces at
nearly the same time under some rare set of circumstances
some condition that should never happen, happens. You know,
like the brown stuff. It just happens and now AMD is up that
particular creek.
In other words you can't really try to replicate it.Even with code known to cause the bug , it might not happen all the time.
Montecito experienced a similar problem with different clock domains for the cores and the L3 which was asynchronous.Foxton which modified frequency in real time depending on power consumption made this a real nightmare.The fix : Foxton disabled and L3 locked at 1600MHz.
It will be interesting to see how Nehalem will handle this problem since it also has independent clocks for each core , NB and IMC.Knowing Intel , the caches are also far more aggressive in terms of latency and BW.Add to that HT ; you have 8 threads per device , all targeting a shared l2.
Never said low end cpu would cost $1000, said the PC itself.
Since amd is now both video and proc, its safe to say, if they go bottoms up, that the price of a low end pc could rise from $400 to more around $1000 again.
This is because, intel won't need to produce such a large line of processors to compete, and their can just be like 5, 2 low end , 2 mid range, and a EE.
Anyway, wasn't trying to imply anything in my post, was just saying what I have seen over the years since 1995 in computer prices, and how that could go in reverse w/o competition.
Not a fan boy or whatever, only really 1 company I don't like with good reason and its not amd or intel ,love them both, amd I still use for low end cheaper gaming machines, that can just focus on the video card, then rest of system is done for under $300
Just wondering if anyone noticed the early silicone in brackets, possible early samples of B3 still contain the bug and possible later ones wont. But still doesnt make any different as this bug hasnt really happended to any one has it..
Its like the chances perhaps of a CPU HSF falling off, its a possibility but never really happens to anyone.. well unless your god dam unlucky :ROTF:
If it doesnt effect you why worry...
Who cares above 2100Mhz right now? It doesnt even work at 1800 or 2000Mhz. The only thing that matters is the core speed for the bug.
Also they can not test it as such.
And if AMD had actually told the truth. It wouldnt even be an issue for desktops users. In short they lied about the impact as so many other companies.
The simple most straightforward fix for a hardware virtualization issue is DISABLE IT. Yet AMD choose to default have the TLB patch on with or without virtualization.
They don't mention the TLB bug specifically but this is the one they're talking about anyway.
Don't know about 9550 and 9650 being pushed back.
Now there is another French site saying they contacted AMD France to clarify the matter and have been officially told that there actually were no problem and that 9700 and 9900 had started to get in big OEMs hands, that they were ramping up the delivery and that everything was still on track for a worlwide launch at the end of this quarter.
http://www.presence-pc.com/actualite...-retard-27203/
inq confirmed NO TLB BUG ON B3! ;)
