Hello all, I have done 1012 already on the TEAM Xtreem 1600 CL7 with 2.1V.. will be posting soon :)
just saw this thread :D.....
Join in DDR3-1000 MHz Club with P35T-DQ6 (August 2007 hahahaha)
http://valid.x86-secret.com/show_oc.php?id=230935
http://img.photobucket.com/albums/v6...00CL8_pi1m.jpg
Brand: OCZ
Model: Pc8500 (533mhz) 7-7-7 Gold (D9GTN)
Voltage: Vdimm 2.32V / Vmch 1.81V
Timings: 7-7-7-18-1T
Frequency: 1000MHz
Cooling: Air, 120-mm fan
Motherboard: Asus Blitz Extreme.
http://boblemagnifique36.free.fr/Ove...go/1000mhz.JPG
I just hit 1000mhz with 4g of memory!!! is this the first?
Brand: OCZ
Model: 1600 7-7-7
Voltage: Vdimm 2.16V / Vmch 1.71V
Timings: 8-8-8-24-2T
Frequency: 1000MHz
Cooling: Air, corsair mem fan
Motherboard: Asus Maximus Extreme
http://i37.photobucket.com/albums/e8...ander/1m-1.jpg
list updated + some color corrections.
if you find in your result some missing or incorrect data, please drop me a pm with the correct value. ;)
Here is what could do with my kit :)
Brand: TEAM Xtreem
Model: 1600 CL 7
Voltage: Vdimm 2.15V
Timings: 8-7-6-18-1T
Frequency: 1019.6MHz
Cooling: Air, 120mm
Motherboard: Gigabyte X48T-DQ6 [F4H]
http://www.thehardwarelabs.com/forum...179d5cb66d.jpg
Sorry guys, but had limited time hence could not bench for 8M or 32M :(
Max Suicide on A-Data Cas 7 vdimm 2.30v
http://valid.x86-secret.com/show_oc.php?id=320111
Maybe next week i will test super pi32m or 3d bench and i try increase little more voltage again....
Yeah I know, timings are very loose and voltage is pretty high but this was my first attempt at getting into the thread so bare with me! I am continuing to work on getting things tightened up a bit and trying to use some finesse instead of brute strength to get these settings stable. Any advice is greatly appreciated!
Brand: GSkill
Model: F3-12800CL7D-2GBHZ
Size: 2 x 1GB
Voltage: 2.10v (Actual 2.08v)
Timings: 8-7-6-21 2T
Frequency: 1000Mhz
Cooling: Corsairs RAM Cooler
Validation Link HERE
http://img178.imageshack.us/img178/1...dation5.th.jpg
http://img178.imageshack.us/img178/6...idation.th.jpg
hi this is my test:
mobo: maximus xtreme(x38)
e8400
2gb cellshock pc 14400
vdimm : 2.20V bios
7-7-7-21 1010Mhz only validation
http://valid.x86-secret.com/show_oc.php?id=320783
1000Mhz superpi tested
http://img172.imageshack.us/img172/4...7721ms4.th.jpg
Brand: G.skill
Model: F3-12800HZ 7-7-7-18 1,9v
Voltage: Vdimm 2.18V / Vmch 1.69V
Timings: 7-6-5-18-1T
Frequency: 1000MHz
Cooling: Air, Thermalright Ultra120 Extreme + Zalman F3-ZM
Motherboard: Asus Blitz Extreme Bios 1005
http://img160.imageshack.us/img160/6...c71tas6.th.jpg
Brand: G.skill
Voltage: Vdimm 2.04V / Vmch 1.69V
Timings: 8-7-6-18-2T
Frequency: 1060MHz
http://img145.imageshack.us/img145/6...0mhzif0.th.jpg
Nothing special unlike plenty of you guys, but there's a first time for everything. :cool:
Brand: Kingston
Model: HyperX PC3-14400
Voltage: vDimm 2.05V / vMCH 1.85V
Timings: 7-7-7-21-1T
Frequency: 1000MHz
Cooling: Air
Motherboard: Foxconn BlackOps X48 Bios 7
http://www-personal.umich.edu/~gautamb/1000.JPG
looks at all the crazy volts you guys are putting though the RAM to hit 1GHz+ stable on Intel chipset ;) ;) :D
dinos + 790i poking at us ( InteleChipsetters :p: )
[ more of a hint of nF790i's memory overclocking potential :D ]
32M 1000mhz CL6-5-5-12 is darn hard !
Sadly some time will pass before another shot - As Im off for a journey that'll last for a half month.
It seemed too be possible at a bit high voltage though... Sadly we didnt succed...
P5E3:
DICE: CPU, NB, SB, RAM - pictures will be avalible soon I hope :D (heatpipe fun)
.... And that was the coldest DICE I've ever touched... Very low humidity and cold weather... :)
Session started 12:15AM - and ended 0:30AM ;)
- First we started with DDR2 board... Everything just didnt work today, so alot of unforseen things to bypass....
However... 1000mhz 1M stable is easy.. ;)
Dinos, nevermind the volt... Lets just say... Wasnt playing with low voltage today... :D
Name: Bill aka BenchZowner
Brand: CellShock MSC
Model: DDR3-1800 8-7-6 [ Part Number = CS3222580 ]
Size: 2GB Kit ( 2x1GB )
Voltage: 2.25V
Timings: 8-8-8-28
Frequency: 1040.5MHz ( DDR3-2081 )
CPUz Validation: http://valid.x86-secret.com/show_oc.php?id=322915
Cooling: Air Cooling, 25C room temp
Motherboard: Gigabyte X48T-DQ6 Revision 1.1 ( BIOS version F4d )
Just testing Gigabyte's X48T-DQ6 revision 1.1 stability at high memory frequencies.
No tweaks at all, no sub-timings tweaked, etc...
Voltage: 2.13V
Timings: 8-7-6-21
Frequency: 1000MHz ( DDR3-2000 )
CPUz Validation: http://valid.x86-secret.com/show_oc.php?id=323788
http://www.benchzone.com/Benchmarkin...dr2000_32m.jpg
Brand: OCZ
Model: PC3 8500 7-7-7-20 1.5v
Voltage: Vdimm 2.4V / Vmch 1.63V
Timings: 7-6-6-20-1T
Frequency: 1000MHz
Cooling: Air, Antec spot cool
Motherboard: Asus Maximus Extreme Bios 1001
http://cfs11.blog.daum.net/original/...-6-201T32M.jpg
Brand: G.skill / Corsair
Model: F3-12800HZ 7-7-7-18 1,9v / Dominator PC3-14400 7-7-7-20 2v
Voltage: Vdimm 2.24V / Vmch 1.77V
Timings: 7-6-5-18-2T
Frequency: 1000MHz
Cooling: Air
http://img176.imageshack.us/img176/9...ddr3ru1.th.jpg
List Updated :up:
sorry guys, i have not so much time for a lot's of results you made, so i needed to cut the Other test's chart...
so many new mobo's, memory's coming wich could handle 1000mhz easy and the list was a bit mixed so i think it's more clear now...
im still will waiting for 1M, 32M and max Clock results ;)
keep pushing it!
Bala
Here is some pictures of di benching on g.skill sticks...
http://www.odoc.dk/files/dryice/ddr3_iso_l.jpg
http://www.odoc.dk/files/dryice/ddr3_frozen_l.jpg
http://www.odoc.dk/files/dryice/di_ram_ddr3_l.jpg
Not to forget, our fully passive cooled setup lol, di on nb/sb (whole heatpipe system), cpu and sticks...
http://www.odoc.dk/files/dryice/ddr3_open_1_l.jpg
