Very good efficiency on the last 1M run, NewBeetle :up:
Always amazing times from Team Japan,:clap:
any info on revision and week, i looked but might have missed them. best of luck to all for the New Year.
Fine job! New Beetle-san,
Congratulations.:toast:
BTW, The last cooling on this year.;)
By OMEGA
《System》
M/B: ASUS P5E3 WS Pro.
CPU: Core 2 Extreme QX9650(L739A638)
CPU Cooling: LN2
MEMORY: SellShock PC3-14400C8 1GB x2
Vcore: 1.960V, Vio: 3.53V, Vdimm: 2.13V(actual)
HDD:HDS721616PLA380
OS: Windows Server 2003
Power Supply: Zippy460W AC Line 200V
MEMORY 1:2 BIOS 7-6-6-14
CopperPot:OMEGA SpecialⅢ+spider
Grease: Ceramique by Arctic Silver
8M
16M
32M
VERY WELL DONE from team Japan..... :clap: :clap: :D
Can't you use higher fsb?....I'm sure you'll be surprised if you do(can).... ;)
very nice Omega...8m 30sec is smoking :up:
looking forward to higher FSB 32M runs with DDR3 ;)
Again very good job NewBeetle-san and OMEGA3-san! :up:
Very nice work!
おめでとうございます!!!
Faster in world........ Amazing........:up: :up: :up:
omega san PLEASE share your vcore mod
i have the Asus P5E3 DLX which should be similar if not exactly the same for the mods :)
amazing times there wow :D
No , the WS mod doesnt work on E3 DLX :shakes:
This works : http://fugger.netfirms.com/p5e3/P5E3...E_OV_GUIDE.htm
Looks good OMEGA3-san.
Looking forward to updates ;).
Keep pushing it.
Nice speed at 5.7G 32M.
Maybe I need to test DDR3. DDR2 is a little bit slower than DDR3 at 32M.
Again Team Japan Number 1 :) !
When will we see kyosen-sama in action?
Many thanks!
It managed to raise FSB, and it tried by 12 multiplier.
By OMEGA
《System》
CPU Cooling: LN2
Vcore: 1.960V, Vio: 3.51V, Vdimm: 2.13V(actual)
HDD:ST380815AS
8M
http://bird.zero.ad.jp/~zan89925/1_41.688.jpg
16M
http://bird.zero.ad.jp/~zan89925/3_47.657.jpg
32M
http://bird.zero.ad.jp/~zan89925/8_17.391.jpg
great times OMEGA :toast:
Extraordinary 32M run, holy christ what a frequency, and the time is amazing as well, blasting OMEGA-san, also... Outmost impressive frequency on the memory for 32M, also... I must say, you sure know your way around the timings.. ;)
Brilliant runs, Omega, less than 8s away from Hipro5's score :)
Is there more left in the setup?
Very well done OMEGA-san! That PL6 @478FSB : 956MHz tCL6 is just amazing IMHO.
Really impressive update Omega-san.
Good to see some more fsb and good speed and the mem aswell.
Keep pushing it.
congratz OMEGA3- san :up: beautiful 32M run.
