:D MAXIMUS EXTREME rules:
http://img255.imageshack.us/img255/3...5ghz32mhy6.jpg
:up:
:up:
Hmm 10c? :)
What Cooling are you using?
make sure you wear a warm jumper for benching sessions camo :)
:D Update:
http://img265.imageshack.us/img265/5858/43ghz32mka8.jpg
:welcome:
New Bios-file available now :
0904
there´s no change-log yet.
So I´ll give it a try.
btw :
Can it be that the CPU-temp seems to appear higher than real ???
What I mean is :
I just changed the board ( this weekend ) - had a ASUS P5N32-E SLI ( nForce 680i ) before... now I realise that the CPU appears much higher than the core-temps ... I am used to it that it was in fact vice versa.
thanks smooth
i'll give it a whirl
ok, now after the flash is done *g*
my problem with the difference between CPU- and core -temp is gone :)
the temps are like they should be.
just forgot to report :
oc like before ... just with little lower cpu-temps.
installed bios 904 all seems ok i will post back if i find any difference to 803 but seems ok
Hmm please more people report! :) been waiting to see if it did bring any good? Fsb, changed in unstable OC etc..
regards!
have anyone test the new 1002 bios?
are there a 1002 too now?
i've just checked it out and the 1002 is for blitz extreme not maximus so don't use it, its obviously been uploaded to wrong folder on asus ftp
Yeah, BE are Blitz , ME Maximus..
soo anymore tried 904?
Im not home, cannot try it ! :)
ah ok sorry i have seen be1002 in the maximus folder and i was thinking that be stands for beta... ok sorry
no worries kowa
Eternal, what clocks you gettin with all that coolin? What about temps?
:D Usually I always try new BIOS - but 0803 is running extremely nice so I will keep it untill someone post some improvement here with 0904...:p:
:welcome:
well seems that the temps are lower now...but a bit too low.
gonna test the fsb with a qx9650/e6850 later that day.
can anyone post results maximus extreme with Quad Cores???
@z3ro-cool :0803
how do you get his post as he would want the Bios? :)
When I logged on a few hours ago... there was another post concerning the question if sombody could load him 0803 cause ASUS took it off the server.
But now this post is gone ... or maybe I´ll get insane ...
yeah i deleted the post.. @smooth thanks
i found the BIOS on the asus FTP on another server so i downloaded it from there and deleted my post before i saw smooth's post. Thanks for the help though smooth :) danke
Just looking for Maximus extreme users with quad cores.
