pushing air through mine with delta 75cfm 120x25mm fan
http://i4memory.com/reviewimages/coo...extreme_02.JPG
one thing i learnt from scythe infinity experience is push the fan further down the heatsink so it cools the cpu socket area as well :)
yeah i am suprised as well as my temps for the first 2 cores tend to run about 3 to 4c higher then the other 2 cores.
depends on board and cooling i guess.. on Blitz extreme when i changed over to dtek fuzion cooling now under load core 0/1 don't move from 38C and only core 2/3 go a tad higher LOL
http://fileshosts.com/intel/Asus/Bli...ime95_load.png
http://fileshosts.com/intel/Asus/Bli...0m49s812ms.png
Internal beta.. wait to next official release from author or email him for a copy of it :)
That means my friend, that the temps you had with the Tuniq were even worse. Coretemp 0.95.6 is the real deal on temps, so to the temps you had before with the tuniq, add +5C to the temps you posted.
I'm goig on vacation, but when I come back I'm going to try the pull/push configuration o my TRUE. It is installed verically, my TRUE is also lapped and I've added a washer to make it really really tight to the mobo. (the so called "coin/washer mod")
Stay with that TRUE fade, I think Tuniq is not going to help you betterwith this chip. ATM the TRUE is the best option to run stuff on air.
