Slooooow progress short update
Hey guys and girls, haven't had much time lately but here is a small update ;)
These are some photos of the reservoirs I'm using, they are AlphaCool Cape Bullseye reservoirs. I really like how they look and they hold enough fluid to be practical too.
I chose the fancy mounting options and also the 'melvin pipe' which is a tube that extends from the center opening into the middle of the reservoir - it makes bleeding a whole lot easier!
I've decided to start using larger images. Lemme know if you like!
http://www.brimbo.com/temp/mozartbuild/bayres_001.jpg
Here you see the res as it comes from the factory - with the pre-installed mounting gizmo (which I don't need).
http://www.brimbo.com/temp/mozartbuild/bayres_002.jpg
Closeup of the res. Made of POM (Delrin I think). Also you can see the plastic plug used for adding LED lighting if you wish. I'm thinking about using all 3 plugs, with Red Green and Blue LEDs. I can connect them to a microcontroller and do some crazy lighting effects inside the res ... maybe later!
http://www.brimbo.com/temp/mozartbuild/bayres_003.jpg
Another closeup - here you can see the Koolance barb fitting in the center vs. the EK fittings on each side. I fell in love with the Koolance fittings and will replace all the EK fittings when I get around to it.
http://www.brimbo.com/temp/mozartbuild/bayres_004.jpg
Assembled into bay holder
http://www.brimbo.com/temp/mozartbuild/bayres_005.jpg
Just a cool shot, playing with camera settings :)
http://www.brimbo.com/temp/mozartbuild/bayres_006.jpg
Here you can clearly see the Melvin Pipe in the center
http://www.brimbo.com/temp/mozartbuild/bayres_007.jpg
I LOVE LOVE LOVE these Koolance fittings! They're expensive, but well worth it for the level of quality ...
http://www.brimbo.com/temp/mozartbuild/bayres_008.jpg
From left to right: EK barb, Koolance barb, EK stubby (useless!), Koolance compression 90 degree. You can also see the notch cut into the Koolance compression fitting at the top, which works great with a quarter to make 'em nice and tight
http://www.brimbo.com/temp/mozartbuild/bayres_009.jpg
Can you say FUGLY? These are the EK barbs in the EK blocks. Not only do they look terrible, but the diameter of the thread ends is slightly oversize. This makes them difficult to thread in (have to use a wrench) and when you remove them you have little bits of Delrin (like hairs) on the inside of the blocks. Not good! In contrast, the Koolance fittings thread in easily by hand and fit absolutely perfectly. Furthermore, the threads on the Koolance fittings are shorter so they don't protrude into the blocks as far - particularly important on the copper side of FC 8800GTX blocks. You don't have to use that goofy spacer provided with the block ...
http://www.brimbo.com/temp/mozartbuild/bayres_010.jpg
A good closeup of the EK barbs vs Koolance compression. Quality!
I know I'm gushing about the Koolance fittings, but they do have a bad side. They rust very quickly. I left distilled H20 in the system for a week, thinking everything would be ok for such a short period, and found rust inside all the fittings before I could add anti-corrosives. Ever since I changed the fluid I haven't seen any more rust but just be aware - DO NOT run without anticorrosives for ANY length of time :shocked:
